Who Has The Biggest Cam In A Ls1 Or 6.0???
Old Jul 9, 2008 | 08:39 PM
TXsilverado's Avatar
Default Who Has The Biggest Cam In A Ls1 Or 6.0???
who has it and whats the specs? 5.7 AND 6.0'S ONLY!!! I DONT CARE ABOUT YOUR 408 THATS TECHNICALLY A 6.0 BLOCK
im planning on doing a little experiment here soon. my new transmission is on the way and im planning to have my converter restalled from 3600 to 4000 rpm.
i plan to take my truck to the track with that setup and make 3 passes.
over the next week im guna pull my 226/226 .584/.584 112+4 XER cam and install a 237/242 .603/.609 112+1 XER and have charlie wheatley tune her up guna take it out and make another 3 passes and compare the differences and post them up.
if i like the cam im guna pull it out and install a MS4 which is better suited for my heads (239/242, .649"/.609 111 LSA). i will make those damn 11's on motor
Old Jul 9, 2008 | 08:55 PM
07redchevy's Avatar
damn hope you see them 11's you got a real fast truck there
Old Jul 9, 2008 | 08:56 PM
07redchevy's Avatar
well sammy had a 232/230 on his ls1 on a 110
Old Jul 9, 2008 | 09:01 PM
i know some guys are running bigger than that though. theres a dyno graph on tech of the 237/242 that shows 300 hp at 4700 rpm but 400 at 5800 rpm!!! good lord it comes in hard.
Old Jul 9, 2008 | 09:09 PM
07redchevy's Avatar
damn thats good i hope you see good numbers with that cam.
Old Jul 9, 2008 | 09:56 PM
ap2002's Avatar
i know "la cuerva" runs a pretty big cam like the one you are going to try out, and he runs 12.0 on his RCSB,
well damn stew, you are going to have to be the guinea pig on this one, cause if it works for you, i'll definately be sticking it in my truck!
Old Jul 9, 2008 | 09:57 PM
ap2002's Avatar
http://s20.photobucket.com/albums/b2...t=DSCF0924.flv
Old Jul 9, 2008 | 09:58 PM
ap2002's Avatar
Sammy HAS a 228/232 .58x/.59x 110lsa
Old Jul 9, 2008 | 10:02 PM
07redchevy's Avatar
he told me at work a 232/230
Old Jul 9, 2008 | 10:05 PM
dirt track racer 81's Avatar
when i get around to gettin my truck back together. gotta set of milled .030 243 heads and comp 244/248 .612/.615 112 lsa cam to go back in..kinda wish it had a little more lift for that duratiom..might stick some 1.8 rockers someday if i get interested in it again
