Where to gain power on na 5.3
Old May 3, 2022 | 08:11 PM
  #21
Kreemy's Avatar
Originally Posted by arthursc2
You motor is 9.5:1
The LS2 is 10.9:1 and rated for 200k service life on 91 octane, You can add a lot more compression and be totally fine
ok any head recommendations looking to go rectangle port heads because of a future lsa blower
Old May 3, 2022 | 08:22 PM
  #22
arthursc2's Avatar
You can't. Square port heads only fit 4.00" bores or bigger
get the 706s ported and 2.0 valves put in them
Old May 3, 2022 | 08:32 PM
  #23
ZO6Ted's Avatar
LS...life was so simple then. WTF was I thinking
Old May 3, 2022 | 09:48 PM
  #24
terravast4's Avatar
if you are hell bent on buying heads. Im running the trick flow gen x head. Im running the 225 on my stroker but a 215 might suite the 5.3 better. I personally think you should run stockers, get long tubes and if you go boost just run it. Dont overcomplicate it and if you choose to….. do your research.
Old May 3, 2022 | 09:51 PM
  #25
terravast4's Avatar
oh. Run a tvs 1900 on those cathedral heads
Old May 3, 2022 | 10:22 PM
  #26
RedXray's Avatar
100% Redneck
doesn't adding compression also command for better fuel
Not necessarily...
Old May 4, 2022 | 03:56 AM
  #27
Kreemy's Avatar
Originally Posted by RedXray
the thing is the truck likes to back fire and struggles starting with regular 91 without additve
Old May 4, 2022 | 05:03 AM
  #28
smokinlmm's Avatar
Just run the stock heads if your going to put an lsa on it. Heads make basically zero difference if your boosted. Bump compression and roll with it.
Old May 4, 2022 | 06:06 AM
  #29
arthursc2's Avatar
Sounds like you need a better tuner
Old May 4, 2022 | 07:49 AM
  #30
RDF1's Avatar
DuNnO
5 Year Member
I think you need some tuning since octane and starting really dont have anything to do with each other.
