What are you all using for radiators?
Old Sep 30, 2015 | 07:58 AM
Tigger Welder's Avatar
Thanks guys, this is exactly what I needed to know!
Mike
Old Sep 30, 2015 | 10:17 AM
George C....'s Avatar
Formerly ScreamingL
i have a 2010 5.3 crew cab, I tow alot of weight at times
i have a 26' v nose enclosed trailer, combined weight ranges from 13,000-16000lbs depending
few weeks back i was hauling upstate with AC on in 90*heat. I do have a intercooler in front of AC condensor and rad
truck has 34" rad
with AC on ect hit 230* with AC off it would hit 215
on normal days were its not so humid or hot it never leaves off the 210 on the gauge even with AC on
also youre 4l60 is creating alot of heat and if you are going thru the rad its going to heat up the coolant as well
Old Sep 30, 2015 | 09:03 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Why are you worried about 210* coolant temps?
Old Oct 1, 2015 | 07:10 AM
GeorgeC, you say you have an intercooler in front of the radiator and condenser. Is your truck turbo? Or are you saying an additional trans cooler?
I am not worried so much about the absolute temp, as I am the fact that it always runs 170-180 and towing it goes up to 210 and doesn't come down even towing at 60 mph on flat ground. Adding the trans cooler will help, sounds like it will help more than I thought.
Old Oct 1, 2015 | 08:41 AM
Formerly ScreamingL
its procharged
210 is fine for towing
old motorhead
Sep 29, 2015 08:22 PM
TrickTurbo
Sep 25, 2015 11:22 AM
whitelazer
Sep 22, 2015 09:38 PM
Roody0209
Sep 17, 2015 09:06 AM
