What year 5.3 block do i have??
Old 01-02-2012, 07:25 PM
peterls1's Avatar
Default What year 5.3 block do i have??
Just wondering how to know what year block u have when purchased guy had no idea and have some arp head bolts but they seem way long so i might have an older block that takes the short bolts, any info can help like running a number off the block or something.....thanks
Old 01-02-2012, 07:44 PM
Custm2500's Rude Friend
1FastBrick's Avatar
on the top side of the block near the water pump is a casting date will read some thing like A132. It is always a 4 digit code with the first digit being a letter.
A= January
13= the day of the month
2= 2002
Old 01-03-2012, 08:55 PM
peterls1's Avatar
Default o
Thanks a lot man!
Old 01-03-2012, 09:05 PM
peterls1's Avatar
Default o
What mine appears to read after cleaning is, heres the pic
Old 01-04-2012, 01:08 AM
1FastBrick's Avatar
Thats a tough one.
Looks like
02F04
It could be ment to read as
02 july 2004
I would have to look at some newer blocks to see if thats how it changed.
I know the bolt hole depth is posted on this site some were... the 04 up should all be the same length on the bigger holes.
the 99-03 have the out sides 2 holes in the niddle row are not as deep as the rest.
Old 01-04-2012, 01:19 AM
9 Second Truck Club
stock48's Avatar
The short bolts are 2004 up which is a good thing. You have the better block, rods and pistons.
Old 01-04-2012, 07:33 AM
sprayedenali's Avatar
You sure? I remember the 99-04 having the doffering length bolts and the 04+ all being the same length...? Maybe I'm mixed up tho
Old 01-04-2012, 12:36 PM
peterls1's Avatar
Well I have the long arp bolts and when I lay a head on the block and put in the bolt it literally goes an inch and gets tight with about 4 or 5 inches to go before it ever sinks the while way so I assume I'm needing the shorties..........?
Old 01-04-2012, 03:02 PM
sand man's Avatar
03+ are drive by wire
04+ have better block and shorter bolts
05+ have better heads and better conecting rods
07+ have the bigger intake manifolds+ 87 mm TB
also you can take the part number of the block its in the back on the driver side you can check it online and compare the p#s
Old 01-04-2012, 10:02 PM
1FastBrick's Avatar
Yes you have the 99-03 style bolts you need the 04 up bolts.
Off the top of my head I believe the early bolts were around 6-7 inches long and the later 04 up bolts were around 3 inches long.
I could only find a picture of the 99-03 all side by side. The middle bolt in the picture is the about the same length as all the 04 up bolts. On the 99-03 it only used the shorter M10 middle bolt on the out side of the midle row of bolts.
in 04 they used the shorter style bolts on all the M10
Quick Reply: What year 5.3 block do i have??
