What does it sound like to you???
Old Sep 14, 2009 | 06:49 PM
  #31
00ChevyScott's Avatar
Wearin' da big hat
Just because 1 spring breaks doesn't mean they're unreliable....
Did you let the engine warm up before you drove it hard? I don't even go past 25% throttle until the engine is at op temperature.
Old Sep 14, 2009 | 06:50 PM
  #32
Wearin' da big hat
Old Sep 14, 2009 | 06:57 PM
  #33
D_reks{5.3}'s Avatar
Originally Posted by DozerDan
damn dude...sorry i recommended those! i'm really starting to think the only safe thing to do is use double springs...hopefully you didn't do like me and drive it more after it broke. that will tear some **** up!
Dont be sorry man ha, Not your fault. And ya i stopped the truck right after i felt it fall on its face.
Just found out that i bent an exhaust valve..
Truck was fully warmed, I always make sure its warm before I give it to much pedal.
Old Sep 14, 2009 | 06:59 PM
  #34
UPDATE: i got lucky, I only slightly bent an exhaust valve.. so he is goin to pull the head and see if he can replace the valve, If not then a new to me stock 5.3 head will be goin on..
Old Sep 14, 2009 | 07:01 PM
  #35
Wearin' da big hat
The fact that it broke so quickly on such a mild cam, I think something else must have contributed to it breaking in your case. Either that or it was a factory defect in the spring. I'm running those same springs on my 228R and it is .588 lift and I have rev'd it to 6700 many times.
Old Sep 14, 2009 | 07:06 PM
  #36
I know man, Both me and my tuner are in shock because my cam is no where big enough to break those springs.. We were just thinking a bad batch/spring.
It broke in 2 places also.
So i am thinking of running duals now..
Old Sep 14, 2009 | 07:07 PM
  #37
Mangled03gmc's Avatar
Baltimore Whore
Glad to here it wasn't serious homo... I thought the pacs were doubles???
Old Sep 14, 2009 | 07:09 PM
  #38
Wearin' da big hat
I think it's a pretty proven fact that dual springs do not provide more protection in a spring breakage scenerio. The small spring in the middle is nowhere strong enough to keep the valve up with the engine running. Dual springs can take more abuse and a bit more lift, but they are not bullet proof by all means.
Old Sep 14, 2009 | 07:10 PM
  #39
Wearin' da big hat
The 1218s and 1518s(I think thats the pt number) are beehive springs
Old Sep 14, 2009 | 07:13 PM
  #40
I know they are not bullet proof, But surely my .551 lift will be fine against them.. What would you recommend scott?
Correct.
