View Poll Results: What cam
Custon Pat G cam
50.00%
MS3
30.00%
TV.2
0%
228r
20.00%
Wimpy 212/218
0%
Voters: 10. You may not vote on this poll
What cam for LS1 Dodge Ram
Old Dec 11, 2012 | 08:08 PM
silverz28camaro's Avatar
Default What cam for LS1 Dodge Ram
What Cam for the LS1 Ram?
-Yank sstb3600 9.5in converter
-HSW plate setup with 75 jets in
-3.90 gears
-4500lbs
-stock LS1
-ls6 intake
-longtubes
-Kimbler built 60E
Looking to smash dreams this time around, instead of just hurting feelings, I was thinking set shift points around 6,900 or so with 7200 rev limit, I plan on throwing some rod bolts in and ported/shimed oil pump..might up the shot to 100 with stand alone 110 octane or c116 to keep detonation under control
Old Jan 13, 2013 | 02:32 AM
low2001gmc's Avatar
heads are limiting factor. with some nice ported, i would say ms3 but with stock ls1, prob 228r.
Old Jan 17, 2013 | 09:51 AM
Vortec350ss's Avatar
I agree that the heads will be the limiting factor. If you want to keep it on a budget I would go with LS6 heads and have a custom cam spec'd. Even something smaller then the 228 will make a world of a difference. I gained .5 in the 1/4 mile with my 222/226 and that was on a stock stall. I think in your case with the 3600 it will be an even bigger difference.
Old Jan 17, 2013 | 01:15 PM
03sierraslt's Avatar
I would do ls6 heads and a custom grind.
Old Jan 17, 2013 | 03:01 PM
slowswb's Avatar
ms3 all way 853 and 241 which every heads you have dont flow that bad compared to a 5.3. A ms3 and step up that shoot 100 that truck will roll out.
Old Jan 17, 2013 | 09:55 PM
02 BLK WS6's Avatar
10 Second Club
228r is about as big as you should go with a 3600 yank. If you want to make power to 7k, you'll need a set of ported heads, bigger cam, and higher stall converter to have an optimized setup. I'm sure you could blend the bowls and open up the ports on a set of LS1 heads with your back ground.
If you're bent on keeping the 3600 yank, 228r or custom spec'd cam. What gears/tire size are you running on the rear? Did you ever hook up the 4wd?
Old Jan 17, 2013 | 10:52 PM
Next step is the 4wd..I have all the front end parts on the bench, just looking to get time to assemble a front end..I was planning on looking for a used front end so I can put it together and just swap it in the front one night.
gears are 3.90's on 30in tires..
Got any 15lb bottle laying around?
Old Jan 19, 2013 | 10:02 AM
02 BLK WS6's Avatar
10 Second Club
Bought a boat and sold the Camaro when Gateway closed. The only thing I have left is a bottle heater.
Old Jan 19, 2013 | 03:45 PM
Beatdown Z's Avatar
Laid Back
Custom cam from Ed Curtis, Cam Motion, or Pat G.
Denali08
Aug 9, 2015 04:34 PM
Austino
Jul 30, 2015 03:28 PM
jaypowe11520
Jul 29, 2015 07:59 PM
FlowmasterMufflers
Jul 9, 2015 11:35 AM
Black-Syde
Jul 6, 2015 02:12 PM
