Update on .050 milled heads
Old Dec 19, 2010 | 04:18 PM
1slowz71's Avatar
Default Update on .050 milled heads
So laste week i mention to you guys that i hade a set of heads that were milled .050 , on an lq4 with a 222/228 on a 567 lift , and a few members mentiond that i could run into clearence issues, such as intake manifold not clearing and power steering bracket no lining up and so on.
Well I'am more then happy to let you guys know that i did NOT have any issues with anything everything fit like a glove i must say i did use the stock head gasket , the only thing i did change was the pushrods i replaced the 7.4 with a smaller 7.350 ,
Just wanted to let you guys know kuz i was sh*tt*ng briks through out the whole prosses!
thank for every ones 2cent!
Old Dec 19, 2010 | 04:22 PM
skeet's Avatar
good news glad it all worked out for ya!!
Old Dec 19, 2010 | 04:25 PM
1slowz71's Avatar
thank skeet know if it would only stop rainning in SOCAL.
Old Dec 19, 2010 | 06:12 PM
max1's Avatar
Banned
i've seen .055 mill heads and no problem with intake alligment . . the issue is PVC with a high lift cam..
Old Dec 19, 2010 | 08:12 PM
SincalT/A's Avatar
I think you mean early opening intake valves.By the time any cam reaches max lift the piston is a good distance from the valves.
Old Dec 19, 2010 | 09:02 PM
Rhino79's Avatar
9 Second Club
Small chambered heads,larger valves with large lift numbers, pistons at zero deck or slightly out of the hole, dome design etc can all lead to decrease ptv clearance. And another thing people need to watch is running very close ptv clearance because at higher rpms, it will decrease...
That being said, cams up to about .590 or .600 lift with stock bottoms ends usually dont have clearnce problems. Better safe than sorry!!!
Old Dec 19, 2010 | 10:26 PM
SincalT/A's Avatar
Yeah,All that could be considered too...Except the large valve coupled with large lift.I dont know how you guys are getting large lift involved.Please explain maybe I jus dont understand?Far as I know an early opening intake valve is the main contributer to clearence problems.I mean thats what is checked when cam installs are done correctly right?Its my understanding .080-.100 intake ptv clearence is the norm.
Old Dec 19, 2010 | 10:53 PM
1slowz71's Avatar
i hade the same understanding about ptv clearence , but thankfully everything went perty smooth for me!
Old Dec 20, 2010 | 06:24 PM
99LS1Bird's Avatar
what kinda #s are you making or expecting?
Old Dec 20, 2010 | 06:40 PM
1slowz71's Avatar
iam hoping for 350 rwhp hoping ill be fine with that for know!
