TSP 220r 110lsa
Old Feb 12, 2015 | 02:03 PM
  #31
69Camaro427's Avatar
With factory manifolds you need to increase exhaust duration and decrease the advance. It positions the overlap on the intake stroke which is hugely important with the added exhaust pressure of factory manifolds. Too much advance and you will actually disrupt the intake flow.
Interesting, so headers will allow for more advance or/and a tighter duration without disrupting the intake flow?
Old Feb 12, 2015 | 04:36 PM
  #32
black00chev's Avatar
Slowest turbo build ever!
Well at this point since you're looking for ideas, I'll throw my cam setup in the mix for ya. Ive got the Isky 212/.561/112 from stock48 and Im pretty happy with how it's done so far. Even with the bone stock trans and exhaust manifolds/y-pipe it made 300/310. Ive since added LTs/ORY and 3-inch cat-back and Blackbear tune, makes around 340/330 now. In town milage is like 12-14 and highway is 18-20. I even managed to still get 17mpg with a misfire and pulling a car and trailer 200miles lol.
The cam starts pulling really good around 2500-2600, so a 2800 stall would make things just about perfect for me.
Old Feb 12, 2015 | 05:24 PM
  #33
GREENSIERRA's Avatar
Originally Posted by GM1697
What size tires were you running. And that stall is much bigger than I am willing to commit to.
I was running 36" tires with 5.38 gears.
a 3200 stall is still very very streetable and able to tow
I towed with the 220 cam and 3200 stall all the time with no problems. it was also my daily driver
Old Feb 13, 2015 | 07:56 AM
  #34
GM1697's Avatar
Isn't that cam designed for boosted trucks? But those certainly are good dyno numbers.
Old Feb 13, 2015 | 07:58 AM
  #35
GM1697's Avatar
I'm about to pull the trigger on the Trick 216/220. It's dirt cheap and lets me use ls6 springs, so its a good inexpensive way for me to dive into the world of cams.
Old Feb 13, 2015 | 09:39 AM
  #36
you mean the 216/220?
Old Feb 13, 2015 | 12:48 PM
  #37
GM1697's Avatar
Yes. My bad. I shouldn't be on the forums before I've had my morning coffee.
Old Feb 13, 2015 | 04:22 PM
  #38
Not really per say. It just happens to work really well with boost. It provides the low-mid to get moving and lets the top end carry enough for a turbo to work. PM Stock48 and he would probably be more than happy to suggest a cam.
From what I can tell in my truck, this cam only feels slightly softer off idle than stock, but once it hits 2500 its a whole different game. Mid range pulls very strong and the top end isnt peaky, but pulls just fine in my truck all the way to 63-6400. Even with my stock trans and converter, I can do a burnout from a 5-10mph roll. With a different converter this would be even easier.
Video for fun
Old Feb 13, 2015 | 04:40 PM
  #39
Vortec350ss's Avatar
Yes headers allow for more overlap and allow the engine to cooperate better with more advance. The proper headers will allow for more flow while increasing velocity of the exhaust and literally suck the exhaust out of the combustion chamber... with overlap in the cam it also helps to suck the air into the cylinder from the intake port.
Old Feb 13, 2015 | 09:34 PM
  #40
GM1697's Avatar
So I talked to Stock48 and he recommended a 210/216, .532/.532 108lsa.
