TSP 220r 110lsa
Old Feb 10, 2015 | 08:37 PM
GM1697's Avatar
Default TSP 220r 110lsa
Thoughts on the Texas Speed 220r ground on a 110LSA. Go!
Old Feb 11, 2015 | 12:07 AM
Vortec350ss's Avatar
In a 5.3 that bitch will sing! It'll make great torque. I would probably only add 2* advance if it were mine... keep the overlap closer to TDC. On a 108 ICL it will have a really solid mid range
Old Feb 11, 2015 | 12:41 AM
GM_Devil's Avatar
would still recommend a higher stall converter.
Old Feb 11, 2015 | 12:55 AM
oh itll definitely need a stall in a 5.3... itll be aggressive and way too lopey for a stock stall.
Old Feb 11, 2015 | 09:34 AM
RS/SS 4.8's Avatar
10 Second Truck Club
I got a 220/581/112 in my 4.8. Pulls good but your going to need a stall.
20121125_101433.mp4 Video by fsvega88 | Photobucket
Old Feb 11, 2015 | 10:05 AM
GM1697's Avatar
Most likely going to go with a TB converter, is that too little? I'd prefer to use this converter because my current trans is stock, except servo and transgo hd2.
So throwing a 100 dollar converter in it seems like a good idea, because I won't have any hurt feelings nuking the cheap converter when the whole trans goes out. Then the whole thing will need an overhaul and at that time a nice converter can go in with all other upgraded internals.
Old Feb 11, 2015 | 10:10 AM
It will feel ok, but it will like more.
Old Feb 11, 2015 | 10:29 AM
GM1697's Avatar
What would you consider ideal? I'm also trying to not destroy my mpg if possible, whereas I feel anything over 3k stall will do so.
Old Feb 11, 2015 | 10:33 AM
A cam with that much overlap in a 5.3 will hurt MPG in any situation outside of maybe highway cruising.
I would say at a minimum for it to feel strong off the line you will want a 3000.
Old Feb 11, 2015 | 10:42 AM
GM1697's Avatar
What cam grind would match a 2600 stall better? I'm really trying to just gain as much as possible while losing nothing
