tr224/224 112lsa in a 5.3 impressions
Old Apr 25, 2006 | 09:23 PM
  #31
THE-HOE's Avatar
so would you say that i should at liest have a 2500 stall to run this cam?
Old Apr 25, 2006 | 10:42 PM
  #32
yes, 2500 would be a good start, 28-3000 better
Old Apr 25, 2006 | 10:45 PM
  #33
white1's Avatar
In a 5.3, Id go 3000-3200 IMO. I have a similar cam in a 6l 4wd and run a 3200, but the cam was designed around a 3000. I had a TB that stalled to 27-2800, and it was a little too small
Old Apr 26, 2006 | 09:45 PM
  #34
why does the trailblazer stall stall so high compared to our stock ones?
Old Apr 27, 2006 | 09:18 PM
  #35
goshawk23's Avatar
Truck addict
they are probably smaller. i have never owned one other than what is in my trailblazer but i would imagine that is the answer.
Old Apr 27, 2006 | 09:25 PM
  #36
white1's Avatar
They are the same size physically, but they are designed to be behind a 6 cyl not an 8 cyl that makes more power. The more power you make the higher the converter will stall
Old Apr 29, 2006 | 07:19 PM
  #37
ONLYA4.8L's Avatar
Old Apr 29, 2006 | 09:45 PM
  #38
Quik's Avatar
5 year bitches!
its like the old days with Opel's converters behind sbcs. small powered motors and stalls then larger powerd motors with same stal will stall higher. since a stall converter goes by a motors torque and this is how you get your stall speed. thats why companies give a range of where the stall will stall unless its custom for your application
Old May 1, 2006 | 10:26 PM
  #39
ah that makes sense, a higher powered engine will push something furthere than was built for a weaker engine to do, thanks, heres the the fuddle 3200 that is in my house calling to be installed
Old May 1, 2006 | 11:18 PM
  #40
Quik's Avatar
5 year bitches!
right on!!!!!!
