TR220 cam questions
Old Oct 5, 2010 | 09:09 AM
baSICK5.0's Avatar
Default TR220 cam questions
I am looking to put a cam in my 01 ECSB silverado. I drive it daily but race it some on the weekends. I previously purchased a 04 Z06 cam and springs, but decided the cam was too mild for N/A like i wanted so I sold the cam.
I Kept the springs and want to buy a new cam to go in my 5.3L that will add some power, sound good and work with my springs.
I was looking at the TR220 on a 112lsa. Sounds good, I dont mind the idle at all. I will be adding a convertor soon as well as gears. I read that the lift is .558 or so and the spirngs are good for .570. is this too close? Can i safely run it with these springs? I dont mind turning an engine hard so I need the springs to be able to handle 5,500 + rpm once every few days.
Give me some guidence. I have tried to search and read but I couldnt really find what i was looking for. Bits and pieces.
Old Oct 5, 2010 | 09:19 AM
skoal bandit's Avatar
I wouldn't think that is cutting it too close. I have .595 lift and was specd beehive .600springs. I went with patriot .650 duals just for good measure though.
Old Oct 5, 2010 | 09:32 AM
baSICK5.0's Avatar
Ok. I just dont wanna find out by ruining an engine. Plus. i already have these springs and new retainers...I can save some bucks if I can use them.
Old Oct 5, 2010 | 10:09 AM
NightmareTBSS's Avatar
Listen to Skoal Bandit bc he just had issues with springs and got his back running!
Old Oct 5, 2010 | 10:32 AM
baSICK5.0's Avatar
yeah I think i will be good. Thanks guys.
Old Oct 5, 2010 | 11:38 AM
budhayes3's Avatar
PT's Slowest Truck
I wouldn't be so worried about the lift as I would the seat pressure with those springs. I know that guys have run TR cams with yellow LS6 springs without problems, but the TR cams are supposed to have aggressive lobes that require extra seat pressure. The PAC 1218's have 130# of closed seat pressure vs. 90# for the LS6's, so if I were to run a TR220 those are the springs I'd run. As I mentioned though, guys have done it in the past without any problems.
Old Oct 5, 2010 | 12:14 PM
get the PAC 1218s like Bud said with that tr220, cant go wrong with them.
Old Oct 5, 2010 | 12:35 PM
02'Z71ONDUBZ''s Avatar
Maybe you have a later batch, but I thought the ZO6 springs were only good to .550 lift? IMO, sell you springs and pick up a set of PAC 1218's. SDPC sells them for $124 IIRC. It would be worth the added security to me. Also, you could go with the TSP 220 if you wanted a little more lift.
Old Oct 5, 2010 | 12:58 PM
If you decide to go with dual springs, MAKE DAMN SURE YOU CHANGE THE SEATS OUT TOO! I know from experience! I broke 10 out of my 16 springs and pulled a chunk out the head with the rocker!
Old Oct 5, 2010 | 01:38 PM
baSICK5.0's Avatar
The springs are 04 springs...
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
