Those with aftermarket cam shafts
Old Aug 8, 2006 | 04:29 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
ls1howto.com
Not to mention if you need a little guidance I can PM you my number and while ur doing it walk you through it, I have done it MANY times
Old Aug 8, 2006 | 08:44 PM
2004SSS's Avatar
i honestly know i could do it i just want someone to be able to show me what to do and what not do . a buddy of mine is very experienced in ls1 performance builds so i think he is going to help me. hopefully this wont happen again and this time its getting with the lpe oil pump!
Old Aug 8, 2006 | 11:41 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Originally Posted by TIM Z
Btw thats a saucy broad in your sig!!!
I second that!! Twice!
I have a 210/218 .551 .551 112 in my 6L/Radix. So far so good. This was in a brand new LQ4. Changed the rod bolts (Kaetech), springs, hardened pushrods, Kaeteck oil pump and was done.
Old Aug 12, 2006 | 09:26 AM
gonzo 6.2's Avatar
Originally Posted by 2004SSS
how long have you had it in for and did you chenge anything besiides your cam(bearings/springs/etc). and this is mostly applying to blown guys with gen 3 engines( preferbly 6.0's)
the reason im asking is i have a vortech with a futral 213-219-15 +3 cam. well i did have one it spoun a cam bearing . so im etting a new lq9 motor and i want to get another cam i just dont want anything to happen. im not looking to rebuild the whole motor just for new cam bearings.I just want to see if anyone has had any troubles with the same stuff or if you have had good luck with your set up and maybe some ideas of why this happened to me so i can avoid it next time around
Doesnt cammotions build cams for futral?If so there have been others that have spun cam bearings.
Old Aug 12, 2006 | 01:12 PM
2004SSS's Avatar
well i got all the parts i need short of the new cam. i got the lpe oil pump comp springs rods and ti retainers. the one thing i need that i cant figure out though is the valve sapring locks, anyone know which angle and what size we need for 6.0's?
Old Aug 12, 2006 | 01:32 PM
1SlowHoe's Avatar
I re-used the stock ones from my 5.3.
Old Aug 13, 2006 | 12:23 PM
TravisH's Avatar
I say do the install yourself. I dont have that good of mechanic skills and only basic hand tools(I had to buy a valvespring compressor from Napa and pen magnets) and I did mine myself. It actaully a lot easier than it seems. I used the ls1how-to write up to guide me through it.
All ya gotta do is pull the radiator, water pump. front cover, cam gear, and cam retainer and your there. Springs are another story though, I reccomend have 2 ppl for that job(at least with my experience) Took us about 3 hours for that.
Old Aug 13, 2006 | 02:20 PM
moregrip's Avatar
what a rush!
lets keep the posts on topic please
SloSVO
Aug 11, 2015 07:33 PM
JordanH
Aug 8, 2015 07:59 PM
bk_cauley
Jul 8, 2015 05:37 PM
