Those with aftermarket cam shafts
Old Aug 7, 2006 | 07:32 PM
2004SSS's Avatar
Default Those with aftermarket cam shafts
how long have you had it in for and did you chenge anything besiides your cam(bearings/springs/etc). and this is mostly applying to blown guys with gen 3 engines( preferbly 6.0's)
the reason im asking is i have a vortech with a futral 213-219-15 +3 cam. well i did have one it spoun a cam bearing . so im etting a new lq9 motor and i want to get another cam i just dont want anything to happen. im not looking to rebuild the whole motor just for new cam bearings.I just want to see if anyone has had any troubles with the same stuff or if you have had good luck with your set up and maybe some ideas of why this happened to me so i can avoid it next time around
Old Aug 7, 2006 | 07:35 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
My best guess would be that whoever intstalled the cam dinged a cam bearing with a journal or lobe of the cam and it created a sharp point which in turn gaulded a journal or caused lack of oil flow spinning the cam bearing. How do the cam journals look? BTW if you sell ur pistons/rods I would like to have first dibs on them as I will be needing them eventually.
Old Aug 7, 2006 | 07:52 PM
2004SSS's Avatar
well i got a warranty so they used my old engine as a core sorry about that i woul dhave liked to have some parts from it also. but the weird thing is the cam install was quite a while ago at least 5 k miles
TIM Z's Avatar
11 sec. Truck Mod
No prob with my 212-218 comp cam/Z06 valvesprings, gets wound out to 6300 time to time But i had Doctor TJ install so all went well. He's the Man. Sorry bout your prob. man. Btw thats a saucy broad in your sig!!!
Old Aug 7, 2006 | 07:56 PM
1slow01Z71's Avatar
Why do motors last and last under the same conditions then one day give up the ghost? I dont know same could be said for the cam bearing. How do the journals look?
Old Aug 7, 2006 | 08:04 PM
2004SSS's Avatar
im going tommorrow to check it out i havent really seen it in person to much yet. im returning the stock parts and keeping the comp springs/rods and retainers.i just need a trustable instlaler next time around!!
Old Aug 7, 2006 | 08:05 PM
TIM Z's Avatar
11 sec. Truck Mod
where are you located at?
Old Aug 7, 2006 | 08:08 PM
2004SSS's Avatar
far away cali
Old Aug 7, 2006 | 08:10 PM
TIM Z's Avatar
11 sec. Truck Mod
isnt Synergy out your way? Cali is the land of Perf. should be easy to find a good installer, Good luck bro.
Old Aug 7, 2006 | 11:58 PM
moregrip's Avatar
what a rush!
have you given thought to doing the install yourself?
