More 6.0 Questions
Old Aug 12, 2006 | 02:46 PM
dirt track racer 81's Avatar
Default More 6.0 Questions
So i found a lq4 i think..it was hard to see the pistons..its out of a 2002 3/4 work truck 70,000 miles..will this still handle the power of 241 heads low 10.xx compression i assume.., 230/226 .597/.573 cam and 150 shot??
which rod bolts..head bolts, and head gaskets should i use?? i dont want the stretchy basterds unless thats it..
Old Aug 13, 2006 | 08:06 AM
KySilverado's Avatar
I think the LQ4 will handle the power you are talking about. Rod bolts either Katech or ARP. If you are worried about popping head gaskets ARP studs should work nicely.
Old Aug 13, 2006 | 11:40 AM
TravisH's Avatar
I think you are gonna end up blowing a rod out the side of the block again....
IMO you need to build a forged engine...
Old Aug 13, 2006 | 12:10 PM
Rhino79's Avatar
9 Second Club
You could use the ARP head bolts, they are not torque to yield, and some cometic gaskets. That would be a nice setup I believe.
Old Aug 13, 2006 | 03:46 PM
sliderbkt's Avatar
All 8 of my LQ4 rods were bent when my motor popped a piston. This was with 10-12lbs of boost though.
Old Aug 13, 2006 | 04:56 PM
RoninsDenali's Avatar
Another Option for Rod Bolts is the Late model LS6/LS2 bolts.
GM Part Number: 11610158 (quantity 1)
ARPs are nice too, but even with the GM bolts you're break a rod/piston before the rod bolts let go...
ferrellrooster
Mar 6, 2025 03:22 PM
spiritfish
Aug 23, 2015 09:58 PM
chevy6.0fan
Aug 20, 2015 07:10 PM
USMCvet0311
Aug 1, 2015 07:45 AM
justuc
Jul 24, 2015 11:52 PM
