Tapping after cam and spring install
Old Sep 18, 2008 | 08:15 PM
norris_83's Avatar
Default Tapping after cam and spring install
Once I had everything installed, there was a similar nose to that of the dreaded piston slap.. my mechanic told me it was the pushrods maybe being a little bit less in length then what they should be and it would be best to install some longer ones...
what y'all think?
Old Sep 18, 2008 | 08:17 PM
InchUp's Avatar
I'd say he's correct. It should sound more like a sewing machine though if the pushrods are too short.
Old Sep 18, 2008 | 08:20 PM
norris_83's Avatar
its similar to that.. imagine piston slap on all the cylinders constant, but about 50% quiter.. thats what I'm experiencing.. he also said its not a problem and its better coz it doesn't put too much stress on the valvetrain?
Old Sep 18, 2008 | 08:26 PM
hirdlej's Avatar
Your mechanic sounds like a doof. You need a $20 pushrod checker from summit racing and need to check your lifter preload. You should have around .080" lifter preload. Do you need this explained to you on how to check this? I'd be willing to elaborate if it'll help you.
Old Sep 19, 2008 | 03:36 PM
lsx10's Avatar
if he doesnt need it explained more in depth then I'm sure a few others might like the help. i gotta order one of these and unless it explains itself then I could use the help.
ARC
57
Feb 21, 2022 10:54 AM
chevyl33
Aug 24, 2015 08:21 AM
Ammadien
Jul 22, 2015 08:50 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
