Stroker Motor Build For Towing
Old Jul 8, 2012 | 10:45 PM
  #51
GMCtrk's Avatar
Did you dyno with those hummer wheels on? If so, I think your numbers might be right where they should be. That is a huge heavy vehicle to be moving.
Old Jul 9, 2012 | 06:45 AM
  #52
Duntov1967's Avatar
DYNO RUN
Old Jul 9, 2012 | 03:25 PM
  #53
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
How are you running an 8 lug front?
Old Jul 9, 2012 | 03:43 PM
  #54
nonnieselman's Avatar
thats what i was fixin to ask.. thats pretty neat.
Old Jul 9, 2012 | 04:05 PM
  #55
Duntov1967's Avatar
You noticed. Right now I have adapters. But I am real close to doing a 2500 swap complete with a 3/4 diff. with an E-Locker. I am using 1500 Cognito upper arms with 2500 bolt-in ball joints, 2500 knuckles, hubs & brakes. The frame brackets will be moved up 1-1/2" up and 5/16" inboard for proper geometry.
Old Jul 9, 2012 | 05:22 PM
  #56
1FastBrick's Avatar
Custm2500's Rude Friend
Intresting!!! That would be a sweet conversion!!!
Old Aug 7, 2012 | 11:27 PM
  #57
Chevy_freak's Avatar
Ive heard rumor a late 90s dodge 2500 unit bearing will bolt up and be 8 lug. Cant verify myself but itd be way cheaper and easier.
Old Aug 8, 2012 | 08:22 AM
  #58
Tootall's Avatar
have you swapped cams yet?
Old Aug 9, 2012 | 07:39 PM
  #59
Duntov1967's Avatar
Yep, that could be done. But the Dodge has whimpy bearings just like our 1500 series. The GM 2500 has beefier bearings, larger rotors & calipers, ball joints and tie rod ends. Also, with the Dodge I would have to give up my ABS.
Not yet. I have the cam now but I am waiting on the 1.8 ratio rockers. It sure would be nice if a cold front would come here in Florida to make it more enjoyable. It's a beotch being old. LOL
Old Aug 9, 2012 | 07:42 PM
  #60
1slow01Z71's Avatar
Hurry up so I can copy you
