starting hesitation 07nnbs?
it is tuned and has a cam.i was told 2 day that the 5.3 liter timing cover will work good being that the crank sensor is closer 2 the crank and helps read a lot better there 4 eliminating the hesitation issue. does this make sense / shime in
wow, umm yeah the uh crank position sensor is not any where near the timming cover. the reluctor wheel is on the end of the crank. flywheel side not belt side. as far as i know the covers are all the same besides maybe the vvt ones. sounds like it needs a new tuner.
the new NNBS cam position sensors are on the front cover
muncie21
Sep 7, 2015 09:55 PM
LSX-81-SIERRA
Sep 5, 2015 02:51 PM
