solid roller vs hydraulic roller
Old Dec 24, 2008 | 08:05 PM
2004SSS's Avatar
Default solid roller vs hydraulic roller
can some one give me the advantages and disadvantages of going solid vs hydraulic roller?
i know the basics, like adjusting the valvetrain periodically. and will have more wear on parts( spring cam etc)
but is there that much more power to be had with a solid? i know in a car where its spun to past 6500 rpms it will really shine but in a truck im not to sure.
Old Dec 24, 2008 | 08:11 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
same difference, no? I ran solids on my bike for a short while with a big cam. More noise, less float and the things you mentioned.
KySilverado's Avatar
I personally couldn't live with the valve noise from a solid lifter setup in anything I drive a lot.
Old Dec 24, 2008 | 08:12 PM
trever1t's Avatar
beat you to it Roger!
Old Dec 24, 2008 | 11:25 PM
2004SSS's Avatar
well to be more specific, the motor im speaking of will not be a daily , it will be making 1200+ hp with alot of boost .
Old Dec 25, 2008 | 01:50 AM
Stoichiometric's Avatar
Solid is going to be for a huge cam. You need super springs to control the valve with that type of cam at high RPM, the hydraulic lifter cannot deal with that stress. I don't know how much cam you will need to meet your goal? Hopefully not that much. You may need some pretty serious springs though.
Old Dec 25, 2008 | 08:41 PM
2004SSS's Avatar
yeah this wont be for high rpms so i think hydraulic should be ok , im just thinking about trying to crack the exhaust valves open is going to be hard on the hydraulic lifters with all that pressure in them.
Old Dec 27, 2008 | 06:57 PM
Daryn's Avatar
Formerly darynC-10/23/10
my solid roller consist of :
26X -27X @.50 .725 lift
springs are 1.550(BBC)..with a seat pressure of around lb230ish open is around lb700ish
also my rev limit will be around 8500!.
408 solid roller - 1050 dominator alcohol carb-
jscherbs
Mar 24, 2017 07:20 PM
Texas5.3_1251
Mar 5, 2016 08:10 PM
Gadgetized
Oct 22, 2015 09:06 AM
97_ek
Sep 23, 2015 09:16 PM
