Sleeving a 6.0
Old Aug 2, 2010 | 03:42 PM
dirt track racer 81's Avatar
Default Sleeving a 6.0
Any one had a 6.0 sleeved? My cousin in texas has his 6.0 at a machine shop and they dont want to sleeve it they want to just bore that one cylinder out and leave the rest standard bore.
Old Aug 2, 2010 | 06:30 PM
silver-mod-o's Avatar
Hunt&Fisherator
No way Jose. That's rough as he'll on rod and main bearings. That one uneven stronger cylinder will beat the hell out of the entire rotating assembly not to mention the one heavier piston. Will be damn near impossible to balance as well. I'd just bore it and go bigger or resleeve that one hole. I've seen that done with no ill effects. Are the cylinder walls beat up that bad??
Old Aug 2, 2010 | 06:39 PM
I completely agree this will cause a lot of balancing issues plus that hole will have bigger CI than the others have more compression and run leaner plus he's spraying it. Its a veru bad idea in my opinion
Old Aug 2, 2010 | 06:56 PM
MikeGyver's Avatar
I've been running with one sleeved cylinder for three years.
Old Aug 2, 2010 | 07:04 PM
Hunt&Fisherator
Sleeved back to the same displacement I assume?
Old Aug 2, 2010 | 07:11 PM
MikeGyver's Avatar
To the same as whatever the other seven are. I guess the machine shop screwed up one cylinder when they were boring it to make my 408.
No, I didn't get one humongous piston to emulate the sound of a hot cam at idle.
Old Aug 11, 2010 | 10:56 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Sounds like your cousin has his block at the wrong shop... The fact that they even suggested that should be a good Clue that he is at a Terrible shop...
Good Luck!
Old Aug 13, 2010 | 07:28 AM
moes04silverado's Avatar
Good Luck!
ummmm YEAH! no way i would let them do any work! If they suggested boring one cylinder to a bigger bore, they really dont know what they are doing.... JMO!
I only paid 1700 to get my 6L bore with new pistons, .030 bore, bearings, ARP rod bolts.
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
