Rotating Assembly
Old Jan 1, 2010 | 03:39 PM
nxredsled's Avatar
Default Rotating Assembly
I was just wandering who is running a texas speed rotating assembly? I'm looking into the 383 stroker for my 5.3. Any input would be appreciated. Or if you would go a different route just looking for some advice I am saving up now should have the money by may. Also this is going to be a nitrous motor.
Old Jan 1, 2010 | 05:49 PM
Tootall's Avatar
just a suggestion . . . but for the money that you're getting ready to spend for "stroking" a 5.3 . . . . you can spend almost the same money and have the same process done if you start with a 6.0L
Just get a bare block, nothing else.
Old Jan 1, 2010 | 06:57 PM
RibeiroBJJ's Avatar
Praise The Lowered
I also want to do a iron 383...ebay has some balanced eagle kits with probe pistons for $1800...The Texas Speed kits are good, but not balanced...
-FWIW..I want a 383 or 5.7...not interested in a 6.0...kinda weird i guess
Old Jan 1, 2010 | 07:05 PM
00ChevyScott's Avatar
Wearin' da big hat
No offense, but that's kinda retarded, not just weird.
What downside is there to starting with a 6.0 vs a 4.8/5.3
Old Jan 2, 2010 | 10:56 AM
nxredsled's Avatar
Thanx for the info. I will be looking for a 6L block and take it to a 408. Since it will be nitrous what compression do yall recommend?
Old Jan 2, 2010 | 12:38 PM
RibeiroBJJ's Avatar
Praise The Lowered
-Well for starter I live in CALI where the smog ***** verify the block stamp...another would be after a track/street race and the looser walks up and sees a 5.3l block with the PRC 2.5 5.3 heads...looks pretty stock..more sleeper IMO..
-I also like a bunch of the smaller bore/205 cc heads...and I have a maggie 112hh that would not feed a 402/408...and I probably want to use it..
-So in my case its not weird or retarded..just what works "best for me...and perhaps the OP..exactly why I never assume or push my OPINION on anyone..
-Never said a 6.0 had a downside...all what your circumstances are...
Old Jan 2, 2010 | 12:41 PM
RibeiroBJJ's Avatar
Praise The Lowered
9.5:1 to 10.5:1 depending on how big a shot your going to run,with computer controlled EFI you dont have to run your compression as low...make sure you get some Nitrous rings when ordering...
Old Jan 2, 2010 | 02:06 PM
LMSeven's Avatar
You can spray at 15:1, the question is what fueling are you going to run and shot size.
Old Jan 2, 2010 | 06:17 PM
nxredsled's Avatar
I am wanting to spray somewhere in the neighborhood of 200. Im in the middle of doing a fuel system right now? and I was thinking in the 10 to 10.5 to 1 compression, Or more waiting to hear back from texas speed.
blown02408
Oct 1, 2015 01:06 AM
chopperloco
Sep 28, 2015 08:40 AM
sTNT971
Sep 26, 2015 04:22 PM
g6t6o
Sep 26, 2015 10:57 AM
USMCvet0311
Sep 4, 2015 09:43 PM
