rod bolt worries?
Given this mild setup...
5.3 heads(maybe milled for an extra .5 pt up from stock)
cam(mild, not sure of specs yet)
new tranny and stall...
Should I worry about the rod bolts?
should I replace the factory ones with ARP bolts?
or is this concern totally irrational?
depends on where you shift at, im shifting at 6200 right now running 12.4's on my setup but in a week or two when i spray im going to install the rod bolts, ARP 2000 series.
Some will say dont worry about blah blah blah.... I say depending on shiftpoints say over 64 65 hundred go ahead and take the little time it takes to do them. for 100.00 and the piece of mind i dont see why not to install them..
Hope this helps.
BTW Thunder Racing carries them in stock
Hope this helps.
You really only need them if you are spinning the engine fast.
Nitrous would push down on the pistons = no extra stress on the bolts. They only see the tensile stress when the piston changes direction at the top of the bore.
Hope this helps.
Hope this helps.
That was the first thing I did when I got my 6l because I blew my 5.3 due to a rod bolt breaking at about 6000 rpm. Maybe a little less. Heres some carnage
Damn, cant find the really good one
Haha. Here it is. This is where everything exited the building
Yohns Kustom Fab
Aug 25, 2015 06:53 AM
