Rocker tip wear?
Old Oct 17, 2014 | 04:35 PM
GRRR65GTO's Avatar
Default Rocker tip wear?
So I pulled my engine apart to do the lifters and when my dad came out and looked at everything he noticed the rockers are wearing on the tips, like alot. I had some stock rockers that I didnt use and you can really see a difference, theres definitely material wearing away. Has anyone else had this issue?
I have the isky triple 12 212/212 112 lsa .561 lift and the isky springs stock48 recommended for the cam (cant remember what the number is)
I did some searching and one guy said basically any cam above .550 of lift will start messing up a stock valvetrain but plenty of guys run stock rockers....
The only thing that could be it is I didnt check my pushrod length the first time, I just went with 7.4s cause thats what everyone else said, could too long pushrods cause this?
Old Oct 17, 2014 | 04:57 PM
Vortec350ss's Avatar
Thats not good. I havent checked mine... might be worth a look.
Old Oct 17, 2014 | 06:59 PM
69Camaro427's Avatar
Are they contacting the middle of the valve stem? Is there a nice even wear line down the middle of the valves?
Old Oct 17, 2014 | 08:03 PM
trxmxzx's Avatar
13 Second Truck Club
Eeek makes me curious how mine is - been spinning 6300 rpm for years with push rods that are little to long still. When I did my motor I was a newbie- didn't know to check or consider milled heads effect length-
You have a pic? I want to see
Old Oct 17, 2014 | 09:01 PM
Gadgetized's Avatar
Have the heads had a valve job, or were the rockers not properly torqued down to the head? Do you have pics?
Old Oct 17, 2014 | 09:34 PM
GRRR65GTO's Avatar
Yes the heads had a valve job and valve heights were set
Ill get a pic tomorrow morning
No theres no lines everything has worn evenly
I torqued them all down to 22 with a torque wrench everytime
Old Oct 18, 2014 | 12:30 PM
GRRR65GTO's Avatar
Here they are
Old Oct 18, 2014 | 01:17 PM
were all three of those out of the motor or only the one on the right? I'm asking b/c the one on the right has a different wear pattern.
The 2 on the left look like mine did around 110K when I swapped to my rollers
Old Oct 18, 2014 | 01:50 PM
black00chev's Avatar
Slowest turbo build ever!
the one on the right doesn't look like its hardly even worn. kinda strange.
Old Oct 18, 2014 | 09:52 PM
GRRR65GTO's Avatar
No the one on the right was from the junkyard head i got so its from a sfock motor
Well regardless the rockers dont matter because i bought harland sharps. So is this much wear normal? And my truck before I tore into it has 114k and i dont think my rockers looked like that
