Rocker tip wear?
Old Oct 18, 2014 | 10:05 PM
mdwatts11's Avatar
I thought most guys use 7.350" push rods with the triple 12 and ls7 lifters?
Old Oct 18, 2014 | 10:13 PM
GMCtrk's Avatar
There's no standard, pushrod length needs to be measured. I'm using 7.325" pushrods with triple 12 and ls7 lifters, albeit my heads are milled.
Most can get away with guessing pushrod length because of the wide range of plunger movement with stock lifters.
Old Oct 19, 2014 | 08:33 AM
GRRR65GTO's Avatar
I just put ls7 lifters in and measured for pushrod size and i ended up getting 7.350 pushrods, before I was running the originals from 2002 with 7.4 cause "thats what everybody runs"
Old Oct 19, 2014 | 11:52 AM
69Camaro427's Avatar
With the cam in my sig, Ls7 lifters, 0.03 milled heads, and stock 0.051 head gaskets. I originally ran 7.350 b/c I had to guess b/c its my dd. They were to nosie so I checked the height and come to find out I needed 7.375". So I don't think the extra 0.05 height of the Ls7 should be taken into account since they are a direct replacement, or at least from my experience it seems I only had to shorten the pushrod for the milling not the lifter.
Old Oct 19, 2014 | 09:19 PM
Doc_speeder's Avatar
Could a small amount of spring bind be causing this without massively destroying anything else? I don't know, just throwing it out there.
Miguel199
Oct 16, 2015 08:04 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
redbird555
Sep 30, 2015 09:28 AM
tim wellington
Sep 29, 2015 10:17 PM
2500ZL1
Sep 12, 2015 03:50 PM
