Rocker Questions - Who has busted them?
Old May 29, 2008 | 04:05 PM
wkdivr's Avatar
I think you got your pushrod geometry all fucked up. You had the heads off, and got them milled. You need to find out if whoever put them back on compensated for that with the gaskets, then get ahold of a pushrod length checking tool, and determine what length pushrods you need. The stock length is 7.400.
Old May 30, 2008 | 08:50 PM
Slowhawk's Avatar
LS1Tech Sponsor
I agree with everything.Definitely have no idea how to check geometry or set preload right
Old May 31, 2008 | 09:08 PM
JJsnowking's Avatar
You dont? Oh man I could be in some trouble I knew I should have brought it to the guy that builds Hyundai's
Old Jun 2, 2008 | 06:39 AM
dhpro's Avatar
FYI...Was reading ur sig: I was originally gonna go to TRannyman for my 4L80...prob wuda saved me the second rebuild!
Old Jun 13, 2008 | 03:51 PM
FlaBouy's Avatar
Preloads are .020 to .060 on stock setups and previous post about no lash adjustment is correct. Just torque to 22 ft lbs. FWIW, my 1.85:1 rockers use a Crane Cam 7.250" pushrod due to the geometry change...
Crane Cam 7.250
Good Luck
Old Jun 13, 2008 | 05:26 PM
Slowhawk's Avatar
LS1Tech Sponsor
Crane Cam 7.250
Good Luck
.020-.060 You must be running Comp R's or Morels. Stock lifters like .080 to .120.
Old Jun 13, 2008 | 05:31 PM
FlaBouy's Avatar
....Stock lifters like .080 to .120.
That's correct.. my bad.. I just put in the Comp 875-16's.... that was the pre-loads I quoted...
chvy=power
Sep 8, 2015 11:06 AM
Alco
Sep 4, 2015 04:08 PM
BigEd_72455
Aug 8, 2015 07:37 PM
USMCvet0311
Aug 1, 2015 07:45 AM
N/ALS1
11
Jul 13, 2015 10:56 PM
