rocker arms replacment
Old Feb 2, 2006 | 08:53 AM
jus1975's Avatar
Default rocker arms replacment
Did you guys use poly locks when replacing your rockers, or did you just use stock nuts. And what about the valve stem locks, did you use new ones or the stock ones.
Old Feb 4, 2006 | 10:00 PM
jus1975's Avatar
come on. Its not a hard question
Old Feb 4, 2006 | 10:49 PM
Rhino79's Avatar
9 Second Club
You can use the stock locks, and the stock rockers on the Gen 3's just have a bolt through the rocker center and are torqued to 22 ft. lbs.
Old Feb 5, 2006 | 01:43 AM
eallanboggs's Avatar
Are you asking the actual question you really want to ask? The OEM rockers do NOT use polylocks nor do they need locks to keep them in place.
Old Feb 5, 2006 | 04:48 PM
jus1975's Avatar
No, when replacing the stock rockers with some comp cam rockers did anyone use the poly locks or did you just use the stock nuts.
Old Feb 5, 2006 | 11:49 PM
The Comp Pro Mags use guide plates and studs along with polylocks for preload adjustment and set screws to keep them in place once they are set. The OEM rockers use bolts thru the trunion so they can NOT be used with the Pro Mags
Old Feb 7, 2006 | 06:33 PM
99Silver6.0's Avatar
Do NOT use stock pushrods with the guide plates!!!!!!
Old Feb 8, 2006 | 07:27 AM
jus1975's Avatar
Alright, I'm getting confused here. If I have the pro mag rockers do I need anything extra.
Old Feb 8, 2006 | 04:01 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
No install them like you are suppose to and be done with it. Set the valve lash and all that oyu will also need valve cover spacers or else the rockers will hit the underside of the valve cover.
Old Feb 9, 2006 | 12:39 PM
LS1Tech Sponsor
The preload needs to be set correctly if you do not feel comfortable doing this please have someone that is experienced doing so install them. And to clear them you could always use a good set of custom valve covers
Nate
