rocker arms replacment
The Comp Pro Mags use guide plates and studs along with polylocks for preload adjustment and set screws to keep them in place once they are set. The OEM rockers use bolts thru the trunion so they can NOT be used with the Pro Mags
No install them like you are suppose to and be done with it. Set the valve lash and all that oyu will also need valve cover spacers or else the rockers will hit the underside of the valve cover.
LS1Tech Sponsor
The preload needs to be set correctly if you do not feel comfortable doing this please have someone that is experienced doing so install them. And to clear them you could always use a good set of custom valve covers
Nate
Nate
