Richard ? on 799 castings
I saw the other post you just replied to. I have a 5.3 Ho in the shop with 799 casting heads on it. They have the 2" intake valves are the ports the same as 243? What about the chambers? Is this a good head to put on a mild 6.0 with a 205/212 .540/.540 116.5 CL cam.
I got to get up close with the hybrid prototypes at the GM plant here in Arlington and they had 799 casting heads on them as well.. Not really an answer to your Q's but might be interesting to know.
-Lurius
-Lurius
The 799 casting was mainly used as a pre production head. I'm not sure how many early ZO6's were shipped with them, but I don't think too many because I have only seen them on a very rare ocassion. They are virtually the same as the 243 casting. In fact, I used a pair of 799 heads to test our Stage 2 LS6 program on and the cleanup was complete. Compression ratio will end up with around 10:1 with a stock volume chamber. Your cam is a bit on the small side, but it will make boat loads of torque from the crack of the throttle to 5500 rpms.
Let me know if this helps.
Good luck,
Richard
Good luck,
Richard
This motor came out of a 05 4x4 ECSB. I beleive it's an L33 somebody correct me if I'm wrong. It's all aluminum and has flat tops with these heads. It's factory rated at 10:1 compression and 305HP
Putting the 799 heads on a 5.3l engine is like putting on a ported set of truck heads. Much improved breathing on the LS6 heads. I'll keep a mental note of the fact that 799's have ended up on some 5.3l engines. Thanks for the info.
Regards,
Richard
Regards,
Richard
zblee
Nov 11, 2015 12:41 AM
someotherguy
Oct 5, 2015 12:49 PM
lxcoupe
Oct 4, 2015 08:07 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
