remove broken easy out from head
Old Jul 29, 2013 | 07:39 PM
vipergtrdj's Avatar
Default remove broken easy out from head
Finishing up rebuilding my 5.3 engine and I got all the broken studs removed, then on the last stud the easy out snapped inside of the bolt. It broke below the surface of the head, and I cant get another hole drilled. It jumps around and I don't want to damage the threads. None of the stud is sticking out, so I can't weld a nut to it to remove it.
Anyone have any ideas?
Old Jul 29, 2013 | 07:54 PM
black04's Avatar
Put a nut on top and weld in the middle of the nut to the stud. Its very easy if the engine is out of the truck. The weld will not stick to the aluminum head.
Old Jul 30, 2013 | 01:53 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Or find someone with an EDM Drill or EDM Sinker.
Old Jul 30, 2013 | 09:02 AM
outlawz2004's Avatar
dude easy outs are some hard metal. try using a rotary tool to get you a drill hole started, use some cutting fluid for drill bits and a titanium drill bit and go slow, cobalt bit at the very least.
zblee
63
Jun 10, 2023 01:25 PM
maxspeed05V
Jul 19, 2015 07:08 PM
4B11T
Jul 13, 2015 03:48 PM
