Reluctor Wheel 58x to 24x
Old Apr 25, 2010 | 09:23 PM
Jermoslin's Avatar
Default Reluctor Wheel 58x to 24x
I have a LFA 6.0 out of a 08 Tahoe Hybrid. It has 18k on it. I doing to do a DOD and VVT delete and convert to LS2 but I need to change the reluctor wheel to a 24x. I have someone that's has the alignment tool and is going to change it, but my question is would ya reuse the rod and crank bearings or replace them. Nothing is wrong with them, just remove the crank and reinstalling it.
Old Apr 25, 2010 | 09:27 PM
Mangled03gmc's Avatar
Baltimore Whore
Why not just get the harness that allows you to run the 58t in our trucks?? It is not to exp, you don't have to tear into the engine
Old Apr 25, 2010 | 09:30 PM
Jermoslin's Avatar
Can't find anyone running the converter box and it cost $250. It will only cost $50 for the ring and installing it without beaings.
Old Apr 25, 2010 | 09:31 PM
silver-mod-o's Avatar
Hunt&Fisherator
I got the cam/crank sensor harness and the knock sensor extension harness for about $300 shipped from Lingenfelter. Makes it easier to go back to GEN III in the future if need be.
Old Apr 25, 2010 | 09:40 PM
hirdlej's Avatar
Once you torque down a bearing cap the bearing conforms to the crank and rod journals. I would never reuse a bearing that has been torqued down already. But that's me, I'm picky.
Old Apr 25, 2010 | 09:48 PM
Jermoslin's Avatar
I agree with that, I wish more people were using the converter box. I've been reading good and bad with them. Some say the Lingenfelter TRG-001 is in a redesign right now and hard to get a final answer. Is there any other companies that made a module.
Old Apr 25, 2010 | 09:57 PM
Jermoslin's Avatar
New question. Who is or knows someone that is using the Lingenfelter TRG-001 module on there DD.
Old Apr 25, 2010 | 11:11 PM
budhayes3's Avatar
PT's Slowest Truck
These are my sentiments also, but like Joe, I am very picky and ****. I know very well that these GENIII gaskets are reusable, but still can't bring myself to reuse any of them besides the valve cover gaskets...my LQ9 will be getting new gaskets all around instead of swapping my gaskets over from my 60k 5.3.
Old Apr 26, 2010 | 01:07 AM
pasadenaman's Avatar
Am am getting an ly6 and ditching the VVT and bought the converter box. Itsnt in my truck yet. My installer has not had any problems with that box. He has done about a dozen swaps that needed that. I also ditched the lifters, springs and rods and replaced them with better ones. (ls7 lifters, hardened rods, pac springs.) All from SDPC
Old Apr 26, 2010 | 01:20 AM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
The new redesigned one is TRG-002.
Here's a pic i'll be using one on my GEN IV.
