questions and sugestions on my 5.3 build/setup
Old Aug 29, 2008 | 12:18 AM
10 Second Club
Default questions and sugestions on my 5.3 build/setup
truck in sig w 147k on the clock i have a freash trans and converter siting in the grage and a g80 unit insatalled so im wondering what to do on the motor mods i have bolt on's so here is the run down im picking up a 2003 5.3l long block with 40k on it and what to do with it ?
I was thinking of having the heads milled down a little bit and runing a 03 Z06 cam and i also have a fast 90mm intake tb old set up off my car im going to put on the truck as well.
what to do ?
Old Aug 29, 2008 | 12:24 AM
I would get a hotter cam and also get the heads ported along with milling them so then your 90mm intake can work really well.
Old Aug 29, 2008 | 12:26 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Milling the heads a little will bump compression, good for a few ponies. I think I've read that the car intakes will sacrifice low end torque for a gob more power up top. You might want to go with a larger cam and a higher stalled torque converter if you are going to do that.
Chris I see you beat me to it!
Old Aug 29, 2008 | 12:30 AM
10 Second Club
im also on the look out for a Magie what comp ratio should i be at for the blower ? i wont be doing the blower till next summer unless i get a great deal on one. i could alway's put a set of stock 5.3 heads on when i put the blower on i guess since i have a extra set ?
thanks for the replys
Old Aug 29, 2008 | 12:33 AM
trever1t's Avatar
you know I'm gonna tell you to just buy it now. DOIT.
Old Aug 29, 2008 | 12:40 AM
I Belive I have heard of some people running 6.0 heads on the 5.3 to lower compression to run more boost.
Old Aug 29, 2008 | 01:04 AM
95 bright teal's Avatar
get soem 243's a tr220 and a 3200 stall, can you say twelves
Old Aug 31, 2008 | 12:18 PM
InchUp's Avatar
Can you mill 243's down that much?
Old Sep 3, 2008 | 02:31 AM
10 Second Club
well ive got the motor all torn down just making shure everything was good to go i upgraded to some arp rod bolts for now only mod so far i guess next step will be the 03z06cam and ls6 springs and a good set of push rods also a set of ls7 lifters and gm gaskets will follow as well.
how much should i mill heads ? stock 5.3l heads
ferrellrooster
Mar 6, 2025 03:22 PM
USMCvet0311
Aug 1, 2015 07:45 AM
vmaxpro
Jul 27, 2015 10:45 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
grantpo
Jul 15, 2015 12:21 PM
