Pushrods & Guideplates
Old May 10, 2006 | 08:41 AM
ScojoDak's Avatar
Default Pushrods & Guideplates
Is it absolutely necessary to run guideplates with hardened pushrods?
My valvetrain set up will be HS 1.7 rr's, thick walled hardened pushrods, cloned sausage cam (ground for the 1.7 rr's), mp .600 springs and stock heads (slightly massaged). I dont plan on twisting this Dodge 5.2 Magnum motor past 5500/6000 rpm.
Your thoughts, opinions, suggestions, flames, bashings and insults are encouraged and welcomed. Thanks in advance.
Old May 11, 2006 | 03:46 AM
eallanboggs's Avatar
Are you sure you ask the right question? If so the answer is NO, but the answer to the converse is YES.
SS94S10
Jan 3, 2019 01:57 PM
JordanH
Nov 6, 2015 07:42 PM
jtphelps289
Sep 29, 2015 12:00 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
97_ek
Sep 23, 2015 09:16 PM
