pushrod length????
Old Feb 6, 2007 | 02:47 PM
mcfarlnd's Avatar
Un-Registered User
Question pushrod length????
i have a 2007 4.8l rcsb
i would like to get a cam with the specs: 216/220 112LSA +4 .561/.564. also i want a thinner head gasket of .42 rather than the stock .52. what size push rods would i need? or is this something im going to have to check when i have it assembled in the truck.
Old Feb 7, 2007 | 07:38 AM
TURBHOE's Avatar
any body know how far the pistons stick out of the hole on the 4.8l's i need to know so i know what heads gasket we can use on his eng. .42 should work great but can we close the quench even more?
Old Feb 7, 2007 | 07:14 PM
mcfarlnd's Avatar
Un-Registered User
anybody?????
Old Feb 10, 2007 | 12:54 AM
mcfarlnd's Avatar
Un-Registered User
anyone??? help
Old Feb 10, 2007 | 07:26 AM
FarmerBeau's Avatar
Sexy Party Mod
Gotcha. Here is the pushrod length calculator on tech. http://ourworld.cs.com/ls1info2/Pushrod+calculator.xls It seems to be fairly accurate. Ive used it a few times Make sure you know the base circle of the cam. Hope this helps.
Old Feb 10, 2007 | 08:35 AM
TURBHOE's Avatar
which cam lobes does comp start going away from stock base circle?
Old Feb 10, 2007 | 09:38 AM
02sierraz71_5.3's Avatar
I would buy a length checker with the rest of your order. Probably end up back at 7.4 but geometry is a **** and the best way is to buy a checker the math will always have some margin of error.
Old Feb 10, 2007 | 05:08 PM
NoRice's Avatar
a .42 would be bad very very bad
Old Feb 10, 2007 | 06:06 PM
TURBHOE's Avatar
oh gotcha i was like WHAT then realized lol. .042 there thats better.
Old Feb 14, 2007 | 12:00 AM
Grey Silver's Avatar
11 Second Club
I'm .010 out on my 5.3. I run a .042 cometic so that's .032 quench. Stick out varies from 1 motor to another so you have to measure it.
JordanH
Nov 6, 2015 07:42 PM
jtphelps289
Sep 29, 2015 12:00 PM
97_ek
Sep 23, 2015 09:16 PM
bisqikss
Sep 8, 2015 03:35 AM
