problem with head swap HELP!
Old Jan 10, 2011 | 02:45 AM
  #21
Mangled03gmc's Avatar
Baltimore Whore
What head bolts did you use?? Were they the proper length ones?? There are 2 diff length bolts you can get..
Old Jan 10, 2011 | 06:16 AM
  #22
262_NBS's Avatar
it's possible there was some residual fluid in the "blind" bolt hole which may have caused the block to crack when torqued down.
Old Jan 10, 2011 | 06:36 AM
  #23
Coban's Avatar
My thoughts exactly. BUT, IIRC the difference in length is about 2 inches, so I would assume you would know before the final torque if you had put the wrong bolt in the hole.
Old Jan 10, 2011 | 06:59 AM
  #24
Jake99's Avatar
Its a 98 block so its gots the longer bolts, and it happend in a deep hole. Bolts are new stock replacements i ordered from Sqoggin dickys
Old Jan 10, 2011 | 10:57 AM
  #25
Baltimore Whore
98 would call for the bolts that are 2 diff length's. 04 up would be all the same length's
Old Jan 10, 2011 | 12:39 PM
  #26
OnyxSilveradoSS's Avatar
5.3's are kind of cheap on Craigslist, or better yet a 6.0L
Old Jan 10, 2011 | 08:36 PM
  #27
Jake99's Avatar
Correct it was middle row second from back and i had a long bolt in it.
Old Jan 10, 2011 | 08:38 PM
  #28
Jake99's Avatar
Well I went ahead and put it together and just fired it up, so far everything looks good, no water in the oil, no knocks, no water leaks, so i guess time will tell.
GrooveCityZ71
Aug 31, 2015 12:05 PM
lxcoupe
Jul 14, 2015 10:14 PM
Aboss
Jul 9, 2015 10:28 AM
NuckenFuts
Jul 9, 2015 08:45 AM
GreyChevy
Jul 7, 2015 08:57 PM
