problem with head swap HELP!
Old Jan 8, 2011 | 04:41 PM
Jake99's Avatar
Default problem with head swap HELP!
Im swaping the heads on my ls1, cleaned out all the bolt holes with a straw and an air gun, I bet they were clean enuf to eat out of but when torqueing the heads down i heard a pop and it blew a piece of the block out of the bottom of the bolt hole! What do i do now? can i run it this way? do i need to pull the pan to see what happend? can i even see it if i pull the pan?
Old Jan 8, 2011 | 04:46 PM
fastrt's Avatar
11 Second Truck Club
got a pic? how bad? motor still in the truck? must have still had some fluid in the bottom.
Old Jan 8, 2011 | 05:03 PM
Jake99's Avatar
Cant really do much as far as pics cause the motor is in the truck. I wish i could see the other side, if its no bigger then the size of the bolt hole i would think the block would be ok, just kind of worried about part of the block being inside of my motor.
Old Jan 8, 2011 | 05:59 PM
Jake99's Avatar
Can someone tell me if i will be able to see the hole if i pull the pan of did it break throw another passage?
Old Jan 8, 2011 | 06:18 PM
Gadgetized's Avatar
What do you mean? It cracked the block? It stripped threads out? Did you still have oil in the bolt holes in the block?
Old Jan 8, 2011 | 06:22 PM
BlackGMC's Avatar
Resident Retard
pull the bolt out and shine a flash light down the hole...
Old Jan 8, 2011 | 06:55 PM
Jake99's Avatar
I cleaned the holes out good before pulling the heads on, if i shine into the bolt holes i can see the end of every one but this one is just dark i cant see the end of it. I know theres a hole there. I was doing the first 90 degrees when i heard a pop, thought the bolt snapped cause it was loose again but when i took it out the bolt was fine, no water or oil on it, stuck a wire in there and it gos in alot ferther then the rest, blow air into it i can hear the air going into the motor somewere and less back out of the bolt hole.
Old Jan 8, 2011 | 08:10 PM
hirdlej's Avatar
I'd take a pick and stick it down to see if it's really a hole. If there's a hole, then I'd get a bolt, put some of this **** on it, then put the bolt back in and run it. You've got nothing to lose at this point. I use this stuff on all my head bolts on my big block chevy as the bolts go right into the water jackets. It keeps them from leaking. If you had the holes as clean as you did though, I doubt you cracked anything. Probably just an air fart or something from the tight sealing bolt.
Old Jan 8, 2011 | 09:13 PM
Jake99's Avatar
Yeah i think im going to run it and see what happends. the only thing im really worried about is were the piece of the block went, if it gets lodged it the crank somewere things could ulgy!
Old Jan 9, 2011 | 12:07 AM
Daryn's Avatar
Formerly darynC-10/23/10
i would NOT run it.. you cracked one of the passages.. you will probably be having coolant in your oil when you crank it. or before you even crank it
