Pro Charged DD Build
Old Aug 27, 2020 | 07:46 PM
94m6Z28's Avatar
Default Pro Charged DD Build
have a 09 Silverado 5.3/6 speed going 408 and some boost, looking for advice, i only want to do this once. seems like most builds use BIG cam and a big stall. i wanna stay with a stock stall, maybe a LSA converter at the most. truck is used for everything from towing the boat to taking the dogo for a hair cut.
thinking 9.5/.75:1 to keep it 91/93 oct safe and 8-10psi
lq4 block
summit racing crank and rods - SUM-CR4058125
DSS pistons - K1923-4030
Summit Racing Cam - SUM-8720
218/227 112.2lsa .600 lift
ls9 head gaskets
ls7 lifters
Speed engineering 1 7/8 headers
ls3 heads (823 truck casting)
un touched
stock rockers with trunion upgrade
stock truck intake manifold
Probably stock throttle body - 87mm unless i find a good deal on one
70lb injectors
D1 procharger air to air
i know a d1 will be small on a 408 but its not a RPM monster so 6-6500 rpm max i should be fine...its a truck FFS
oil pump sugestion?
high volume vs high pressure
walbro 450 intank conversion with the CTS-V FICM programming
any input???
Old Aug 27, 2020 | 08:23 PM
FFDP's Avatar
Remember that you have to drill and tap that older block for knock sensors and that you need the correct crank trigger on the crank for your engine.
A high pressure pump or stock will do fine. The high volumes are not needed.
Old Aug 28, 2020 | 10:56 AM
94m6Z28's Avatar
yah, was thikning id use a ly6 knock map/ set up as a base
Old Sep 10, 2020 | 09:59 AM
Summitracing's Avatar
LS1Tech Sponsor
We like your build list/plan. The Pro LS Truck stage 2 high-lift cam SUM-8720 will pair well with your combo. A 2,500+ rpm converter is a plus with that cam but not at all required. Agree with FFDP on the oil pump. The high-pressure Melling MEL-10295 is a popular pump.
Good luck with the build and keep the community updated.
Old Sep 10, 2020 | 12:29 PM
94m6Z28's Avatar
thank you
is their a difference between the Melling 10295 and 10355 ? in the comparison sheet they show pretty much the same
Old Feb 11, 2021 | 02:49 PM
imma_stocker's Avatar
Melling 10295 in my 408 (also LQ based) with high pressure spring. With procharger having self-contained lubrication you won't need the high volume.
Old Feb 16, 2021 | 04:28 PM
94m6Z28's Avatar
its a old D1 oil feed, not the new SC unit
Lq4chevy
11
Oct 19, 2018 07:18 AM
Phantomx55
Jul 16, 2018 05:43 PM
01silvy
Sep 30, 2014 11:16 AM
89LS1FOXER
Nov 16, 2011 05:02 PM
360ATI
Aug 22, 2005 06:14 AM
