Port and polish... HELP MEEEEe
Old Dec 12, 2005 | 11:52 PM
YeLLow Fever's Avatar
Default Port and polish... HELP MEEEEe
ok i just got my comp 918 springs in woohooo .. so here iam happy till my mechanic threw an idea of port and polishing my heads while im at it so i can be at least done with head work ... :/ that means more money to spend .
how much will i gain from porting and polishing ?
how far of porting should i go ?
Any other parts needed when porting and polishing takes place .. e.g Valves etc ?
really appreciate the help ...
P.s im a NoooB
Old Dec 13, 2005 | 05:35 PM
TarheelZ's Avatar
For what it's worth, the word is that the stock heads flow really well and do not require very much in the way of porting. I may be mistaken about this, but I think that a small of amount of pocket porting by someone who knows their stuff will yield 'some' gain for you...but I'm not sure how much! Just make sure the guy is experienced with these heads and doesn't take too much material off when porting.
Good luck!
Old Dec 14, 2005 | 12:04 AM
Richard@WCCH's Avatar
FormerVendor
Is this a 5.3l engine? I'm doing several sets of 5.3l heads this week. I'll post up some results as soon as I finish collecting the data by this weekend.
Richard
Old Dec 14, 2005 | 06:10 AM
tdrumm's Avatar
Richard
Hmm, I think I know where one of those sets are going
Old Dec 15, 2005 | 07:34 PM
budhayes3's Avatar
PT's Slowest Truck
Old Dec 15, 2005 | 07:41 PM
mattrem's Avatar
Good to see Tom, Let me know if you have any questions on swapping
Old Dec 16, 2005 | 06:39 AM
tdrumm's Avatar
In transit.....
I know that I'll have to make time to get them installed sooner than later.
Old Dec 22, 2005 | 08:27 PM
AintNoHo's Avatar
P.s im a NoooB
Headwork with a new cam can yield a lot of power. The best and most expensive is CNC. If done by hand, it's very tedious work and takes time. They say your no.1 cylinder will be good and no.8 will be "good enough". If heads are iron you need air power, aluminum can be done with an electric dremmel. If you want to save money do it yourself (no one will do as good a job). If you need to pay someone, buy new finished heads you'll be happier. When I port, I just remove the slag and sandcasting finish. I also port match to the intake using the gasket and clean up the combustion area. Don't try to hog the ports bigger, I don't think the gain is worth going through the wall into a water passage or casting bubble. You'll be putting JB Weld everywhere. If money is no object, I like the AFR 100% CNC line for the flow numbers. They also make IMO the best smog legal heads.
Last edited by AintNoHo; Dec 22, 2005 at 08:31 PM. Reason: brainfart typed ARP meant AFR
dsbodley
Nov 14, 2015 09:46 PM
gmcyukon
Oct 3, 2015 11:03 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
old motorhead
Sep 29, 2015 08:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
