piston oilers
Old Jan 25, 2009 | 09:27 PM
oldred95's Avatar
Default piston oilers
Do any of you forced induction guys use these? I know diesels have them and they do work. I know they probably aren't a necessary but for longevity maybe they would be a good idea? I can't seem to find any info or pics on this though. Dealing with a Gen I block here.
Old Jan 26, 2009 | 12:23 PM
oldred95's Avatar
Nothing at all? This is suprising.
Old Jan 26, 2009 | 12:36 PM
duwem's Avatar
The new turbo GM 4 cylinder Ecotech engines have them from the factory.
Old Jan 26, 2009 | 02:04 PM
oldred95's Avatar
I know certain engines had them from the factory. I've heard that the Medium Duty 350 engines had piston oilers from the factory. I know the block can be retrofitted to have them but I can't find any info on where to drill, what orfice or tube or whatever was used to direct the oil and so on.
Old Jan 26, 2009 | 03:25 PM
SynergyV8's Avatar
The new ZR1 Corvette engine has them.
Old Jan 26, 2009 | 03:29 PM
oldred95's Avatar
I'm aware of that too. The question isn't what has them, its how can I retrofit my block to have them.
Old Jan 27, 2009 | 05:32 PM
MikeGyver's Avatar
I don't remember if it was Suzuki with their air/oil cooled street bikes or somebody (like Audi) else, they had a hole on the piston side of the rod's big end. Once per revolution it lined up with the oil hole in the crank's rod journal, and give a squirt towards the bottom of the piston.
Old Jan 27, 2009 | 06:07 PM
oldred95's Avatar
I'm aware of that too. I don't recall what engine but there was a Ford that had a that same small hole integrated into the rods.
Again just looking for any info or pics relating to retrofitting a gen I block for piston oilers.
Old Jan 27, 2009 | 06:18 PM
FrostKing's Avatar
Can an oil line be tapped into to make something similar to the new Gen Hemis?
Won't link. http://www.hotrod.com/techarticles/1.../photo_12.html
Old Jan 28, 2009 | 06:55 AM
dhpro's Avatar
There was an article recently in one of the car mags about putting them in as I recall - Chevy Hi-Po or Car Craft(?). I thot I also saw a thread on here as well(?) As I understand it they can be retrofitted, but u may have to clearance some items marginally. There was never any depth of rationale attached however, and I'd like to hear more...as I see it: in the never ending quest for incremental HP, cost/hp escalates exponentially - and thus looks dubious as a retrofit IMO if u dont already have it. R/
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
