oil pump priming
Old Feb 28, 2013 | 06:56 AM
kretty's Avatar
Default oil pump priming
How do I prime my oil pump with the timing set installed? Ive tried turning the motor over with the plugs pulled and coils unplugged. I installed a new oil pump and im not getting any oil to rhe heads. Anybody have any answers? I dont have the whole pressure tank setup so I dont know what to do.
Old Feb 28, 2013 | 08:43 AM
TXSZ66AVLANCHE's Avatar
You can crank all you want with plugs out, no oil pressure is going to build. Ive tried this will a mechanical gauge hooked up, got nothing. Put the plugs back in and fire it up, if you did everything correct oil pressure will be instant.
Old Feb 28, 2013 | 10:25 AM
stall's Avatar
Ya. Just fire it up and let idle. Pressure should take less than 3 seconds.
Old Feb 28, 2013 | 10:35 AM
nonnieselman's Avatar
just hope you used some good engine assembly lube.
If you goin to crank it as soon as you get done with assembly we always used heavy gear oil .
It works.
Old Feb 28, 2013 | 12:34 PM
kretty's Avatar
Thanks. Yeah I used good assembly lube.
Old Feb 28, 2013 | 04:01 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
go to home depot and buy a cheap garden sprayer and attach it to were the oil pressure sender goes and pump it until oil comes out of the pushrods thats how i did mine worked like a charm
Old Feb 28, 2013 | 04:36 PM
Byrdman11's Avatar
Im with Twolow02fransen should works great. I use a home made tank with oil and shop air.
Old Feb 28, 2013 | 07:02 PM
Gadgetized's Avatar
I just did this today. My 05 does not show oil pressure while cranking, but my 99 does. After what I did today, I say to just fire it up and watch the gauge.
pupi305
Sep 14, 2015 11:40 AM
Mossyoakglock
Aug 28, 2015 12:49 PM
JordanH
Aug 8, 2015 07:59 PM
Ferocity02
Jul 17, 2015 07:05 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
