oil pump pickup tube o ring
Old Jan 13, 2013 | 04:11 PM
kelsey_canard's Avatar
Default oil pump pickup tube o ring
Putting the timing chain on the 6.0, and noticed my pickup tube fit a little loose. It has room to wiggle the tube without the retainer tight. I've re installed the tube multiple times. Here's a pic of the o ring.
Notice the flat edges on the outside and inside. Is this normal? Other than that the o ring looks great.
Could just a similar size o ring work? I'm worried after reading people having problems with these.
Old Jan 13, 2013 | 04:18 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Get a new one. Get it from the dealer only.
Old Jan 13, 2013 | 04:20 PM
Are these made with a flat sides on them?
Old Jan 13, 2013 | 04:21 PM
Nope.
Old Jan 13, 2013 | 04:22 PM
Thanks bud
Old Jan 13, 2013 | 07:27 PM
CashDudeHomie's Avatar
Mine was flattened too and would not seal up again. There's a fatter revised one for the trucks. I forgot what color, but the dealer should know exactly what you need.
Old Jan 13, 2013 | 07:29 PM
Ferocity02's Avatar
ALWAYS replace the o-ring. If the sides are flat that's a good indication that it will not seal well anymore.
Old Jan 13, 2013 | 08:02 PM
RS/SS 4.8's Avatar
10 Second Truck Club
I think the truck rings are green. Cars red? I might be wrong because the other day I did a pan gasket and replaced the pump ring since i was there and gm sent me a red one. Fit tight and had oil pressure so I guess thats the new ring.
Old Jan 13, 2013 | 10:07 PM
lglowe's Avatar
I been using red ones.
Old Jan 13, 2013 | 10:10 PM
Ferocity02's Avatar
Ditto.
