Oil dipstick removal, HELP.
That sucks. I thought about doing a resistance weld with a bolt or something. A pin welder for body work is what I had in mind. Clean everything real good and drop a bolt the right size in the hole and hit it with the gun enough to just weld the bolt to the tube and then gently twist & pull it out.
If you drop the pan that little sucker can be tapped out backwards......
Good luck man
Good luck man
I broke mine off when I put my headers on and drilled it out. Then I found the big piece that I didn't realize fell in the oil pan about 6 months later when I did and oil change. Luckily no harm done...
You know you might be able to drive it into the oil pan and leave it there & put a new tube in. The big piece probably wouldn't bother the pick up but I would worry about smaller chips.
you guys that just pulled it out SUCK
I spend 1.5 hours getting mine out when I did my long tube install. Bent it all to heck. I am from the "northern" group though.
Made a pita job of ripping off the old rusty exhaust even more of a task. It was an 8 hour job to pull of the old mainfolds/y pipe and install the long tubes/ ORY...LONG DAY!
I had a hard time with mine as well. I ended up using a screwdriver and prying at it right where the tube meets the block. Once the tip of the screwdriver got under the "lip" I was able to pry it a good 1/2 inch. Then I just pulled her out.
I heard of people using a thin metal coat hanger and bending a small yet very sharp angle hook in it, inserting it down the tube into the pan and then just pulling on it after it catches. Sometimes all you need is just a little encouragement from the other side.
jroctpb
08-11-2015 03:52 PM
