NNBS dod 6.0 swap to 01 SS ???
Old Jan 5, 2016 | 08:57 AM
slowec's Avatar
Default NNBS dod 6.0 swap to 01 SS ???
I have the newer style 6.0 I am putting in a 01 SS camaro. I know I have to deal with a few things to make the switch? What is the best way to swap over. I have all the old parts for the gen 3 engine so I can use all of that I can. Thanks for any input guys!
Block is stripped down and has new cam bearings as of now.
Old Jan 6, 2016 | 08:07 AM
slowec's Avatar
Not everybody at once now!
Old Jan 6, 2016 | 08:24 PM
tim wellington's Avatar
Default what year 6.0
depent on what year .what did it come out of
Old Jan 6, 2016 | 10:17 PM
Tootall's Avatar
Are you using the NNBS 58x crank or swapping the wheel to a 24x?
If not then get the lingenfelter 58x conversion box and run the original 58x crank
The cam sensor is up front, so you'll need the front cover, the cam sensor that goes in the cover and the LS2 cam gear . . . get the extension harness, or extend the wires yourself
The knock sensors are on the side of the block. You're better off getting the adapter harness that goes from the rear of the engine to the sides of the block instead
If anything, use the old crank from the GEN3 engine. That's the only part that I would transfer/get machined again to work on the new engine.
Old Jan 6, 2016 | 10:33 PM
Wolftrk99's Avatar
Are you trying to run dod or get rid of it??
Old Jan 6, 2016 | 10:38 PM
George C....'s Avatar
Formerly ScreamingL
That motor should be VVT
Old Jan 6, 2016 | 10:59 PM
Wolftrk99's Avatar
Depends what it came out of, caprices have dod and no vvt, trucks have vvt no dod...depends if it L77, L96, or whateve it started out as...
Old Jan 11, 2016 | 08:07 AM
slowec's Avatar
Thanks guys! We are using a K1 crank so the 24x part is solved . The front cover/cam sensor and knock sensor was my main concern. Anybody make plug n play cam and knock sensor conversion harnesses? Trying to keep this build very clean. THANKS!
gravedigger472
21
May 23, 2016 08:09 AM
bottledls6
Dec 9, 2015 06:51 PM
Blwn99x
Dec 8, 2015 08:32 PM
DopdBrd
Dec 8, 2015 04:41 PM
