Cam recommendations
Old Dec 7, 2015 | 12:38 PM
Blwn99x's Avatar
Default Cam recommendations
2004 RCSB, 5.3, long tubes/exhaust.4l80,4000 stall, currently 3.42,but going with 4.10 soon. 29" tire. I have a btr stage 3 truck cam (218/224 .553/553 114. Looking for more.also switching to NNBS intake soon also. Occasionally run 100-150 wet shot.
Old Dec 7, 2015 | 01:06 PM
Vortec350ss's Avatar
Wow thats a big converter!
Stock heads I assume? Do you care where your shift points are? How about idle quality? Is it safe to assume this isn't a daily driver?
Old Dec 7, 2015 | 02:22 PM
Blwn99x's Avatar
It is big but I love it. Goes into lock up about 35mph. I stalled it high because of the longer first gear, but again, going 4.10 anyway. Stock 862 heads, have a set of 243 but they need a full run through before I can use them., shift points are at 6200 right now, will have it shift wherever it's most effective.i don't mind rougher idle. And yes it's my daily lol. I don't drive far to work, and next year I will live closer
Old Dec 8, 2015 | 10:55 AM
thompson's Avatar
Banned
With the converter you currently have you could definitely go a bit bigger on the camshaft. I still would be very mindful of the fact that it is still a heavy truck intended for daily use. If you are looking for a little more power and sound I would consider something like a 224/228 on a 112LSA to get you a little more power and sound.
Old Dec 8, 2015 | 08:32 PM
Blwn99x's Avatar
That's what I was thinking. The BTR stage 4 truck cam is 224/230 ..55x/.55x on 111. I could still use my same springs and get a little more out of it. The other thing is I might go turbo and could run the current cam or more cam and more nitrous.So many options. I do have a built 80e trans. I'm not sure what I want haha
diesel cutlass
Dec 17, 2015 08:40 AM
JordanH
Nov 24, 2015 11:23 AM
wickedRCSB
Nov 22, 2015 11:11 AM
2001silverado5.3
Nov 15, 2015 11:13 AM
BCraven1018
Nov 13, 2015 02:02 AM
