new oil pump and flooting psi on new motor
Old Apr 19, 2009 | 09:43 PM
05crew's Avatar
Default new oil pump and flooting psi on new motor
just got the motor in and runs good..but the oil psi goes for 40 down to 20 and back up...the oil pump is form tsp...it is a High flow they SAY...talked to the builder and he felt good about the motor.. and all the clearance...
WTF the motor is like 20mins old..LOl
any info would be helpful...going to put a manual gauge on it tomm.
Old Apr 19, 2009 | 09:45 PM
Mangled03gmc's Avatar
Baltimore Whore
Put a stock pump back in it..
Old Apr 19, 2009 | 09:51 PM
dlt76028's Avatar
i have a high flow from tsp, it works really good. i would look into the connection on the pressure sending unit and possibly put a new one in there. they've been know to go bad, fairly common. also my friends truck did this after the swap and i reached back there and wiggled it and it started reading.
Old Apr 19, 2009 | 10:04 PM
05crew's Avatar
i put a new one on when i put the motor in. the motor is all new top and bottom gaskets and everything..
Old Apr 19, 2009 | 10:55 PM
budhayes3's Avatar
PT's Slowest Truck
What about the o-ring for the pump pickup tube, there are 2 different o-rings available, and one doesn't seal well. I believe that the o-rings are blue and red, and the red one is the one you want...hopefully someone can confirm or correct this info
*EDIT* but first I would check the connection to the oil pressure sender...
Old Apr 20, 2009 | 06:55 AM
05crew's Avatar
ill see what i can find out..thanks for the help
Old Apr 21, 2009 | 08:43 PM
05crew's Avatar
it was the damn o-ring....holding strong as hell......thank godddd
Old Apr 21, 2009 | 09:29 PM
budhayes3's Avatar
PT's Slowest Truck
Cool deal, glad you got it fixed
5.3Okasai
Mar 9, 2022 01:07 PM
chopperloco
Jul 10, 2016 10:45 PM
Bluchevypick
Aug 18, 2015 09:11 AM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
