new heads, old stock?
Old Aug 21, 2006 | 04:53 PM
joshluther's Avatar
Your confused You mill the head surface to raise the compression. I wouldn't go .050 because the ptv clearance is tight depending on the cam you go with. .030 is probably enough. But your gonna need new push rods.
The valve size has nothing to do with milling them. Don't go any bigger than a 2.00" intake valve because it's shrouded by the cylinder wall on the 5.3
Old Aug 21, 2006 | 05:09 PM
o alright, same sized valves, if i go .030 over then i will need what sized pushg rods? 7.35? or what? thanks for your help josh
Old Aug 21, 2006 | 05:15 PM
joshluther's Avatar
If you mill the heads any amount your probably going to need push-rods. I would think .010 and more. More than likely you have 7.40 now and they probably make a little noise now. I have 7.30 or 7.35 in my motor now I can't remember. I am running an MTI C2 cam though.
Old Aug 21, 2006 | 05:33 PM
yea right now i have 7.4. FMS said my cam had stock base circle though. what sized rods do you think i would need if i had the heads milled .030 over?
Old Aug 21, 2006 | 05:38 PM
joshluther's Avatar
7.30" But thats just a guess. You really need to check it. Now that I think about it mine are 7.25. Over
Old Aug 21, 2006 | 05:46 PM
i could just email a tech at futral or comp cams and get their opinion too. thanks for the help though
Old Aug 21, 2006 | 05:57 PM
Richard@WCCH's Avatar
FormerVendor
Originally Posted by joshluther
For what it's worth swapping heads isn't cheap. Your looking at close to $200 in parts gaskets, bolts, etc plus labor. Do it once and get it over with. Send the new heads out to get done. Mill them p&p get bigger intake valves and run them.
Just so you know lifters aren't in your heads but you do have to take them off to change them.
I agree. Your money is best spent modding your new heads instead of trying to fix broken old ones.
Richard
Old Aug 21, 2006 | 05:58 PM
kbracing96's Avatar
It's simple math guys, you take .030 off the heads, you need .030 shorter push rods. If you have 7.4 rods now, you will need 7.370 rod if you shave the heads .030.
Old Aug 21, 2006 | 06:02 PM
Richard
i understand its cheaper that way but the thing is the truck is losing alot of oil right now due to my crappy valves in my current heads and i cant really afford to keep those on during the machining process and drive around drinkin oil. nor can i afford to let my DD sit in a shop for a few weeks. so as it is not as economical to replace the stock heads with the new ones, repair and machine the old ones, then switch again, everytime swapping valves, springs, rockers etc back and forth it is pretty much my only option
Old Aug 21, 2006 | 06:10 PM
FormerVendor
How long will it take to machine the new heads?
Richard
