new cam?
Old Jul 21, 2006 | 07:30 PM
ProStreet83C10's Avatar
Default new cam?
hey guys, im looking into the Comp Cams Xtreme energy cam for my 83 chevy. Heres some specs
Operating Range: 2300-6500 RPM
Duration Advertised: 284° Intake / 296° Exhaust
Duration @ .050'' Lift: 240° Intake / 246° Exhaust
Valve Lift w/1.5 Rockers: .507'' Intake / .510'' Exhaust
Lobe Separation Angle: 110°
Do you think this will be too much cam for it and do you think i iwll be satisfied with the results
Old Jul 21, 2006 | 08:31 PM
AintNoHo's Avatar
That cam's gonna put the torque peak at about 4500rpms or 5000rpms with some good heads. Killer. If you have a 700 tranny, of course, you'll need a 4000 stall to take full advantage. Vacuum assist brakes with 23* of overlap will probably be weak. Idle might need to be raised a little. Don't know what cam and mods you're coming from but if it's near stock you're in for a real surprise.
Old Jul 21, 2006 | 11:03 PM
its fairly stock now.....has 305 heads and an edelbrock intake...those are the main mods. my plan is to do a wild 383 with that cam and some AFR heads and all forged internals mated to a 350 tranny with a gear vendors OD unit.
Old Jul 21, 2006 | 11:52 PM
ScojoDak's Avatar
That's gonna be one lopey sum-bitch! It'll turn heads for sure.
Old Jul 22, 2006 | 07:52 AM
its actually not as wild of an idle as you think it would be, although it will definitly sound aggressive
Old Jul 22, 2006 | 07:58 AM
i could actually go to a .517"/.523" lift but i think thatd be wayy too much and id need a LOT of converter to run it.....like 3500+
Old Jul 22, 2006 | 08:00 AM
Grumpy5.3's Avatar
you need to build a 406 for that truck and be done with it, I have one and I will never build another 383, the torque diffrence is unreal!!!
Brian
Old Jul 22, 2006 | 08:02 AM
fill me in on the 406, what all did it take, what block all the details, i may do this or end up building a big inch small block like a 454 ci SBC
Old Jul 22, 2006 | 08:51 AM
Grumpy5.3's Avatar
If you want anything over a 406, i am gonna say get an aftermarket block. A 406 is just 400 block bored .030 over, 400 crank (3.75 stroke), and some 5.7 rods. that will give you 406 inches. I have one in an S-10, needless to say traction is an issue...
Brian
Old Jul 22, 2006 | 10:59 AM
360demonRT's Avatar
thats a sharp looking truck man. could do with a 2'' drop all the way around imo but it looks good. good luck with it
