new build questions
Old Jul 29, 2012 | 08:09 PM
pillittokillit04's Avatar
Default new build questions
Hey guys got a couple questions I bought a motor from the local salvage yard its a 6.0 out of a 2500 and I've read that its got the longer crank what flywheel am I gonna have to use in my swap can I use my 4.8 flywheel or ??? I'm putting a cam and new heads on it. It'll have the vrx-3 cam from vengeance and 243 heads with the truck intake curious why the compression will be by using stock head gaskets?
Old Jul 31, 2012 | 01:10 AM
iamkeniff's Avatar
What year is the block? 99-02 is longer crank (i think) 03+ has the same length crank as the 5.3
If it is an older 6.0 i think you can run the spacer with your current flexplate.
Compression with stock 243s should be 10:4 or 10:5
Old Jul 31, 2012 | 05:20 AM
01 lq4
GXPJAY
Feb 13, 2022 08:15 AM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 14, 2015 10:28 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
