New build 5.3 base or 6.0
Old Jun 15, 2009 | 09:40 AM
bk_cauley's Avatar
Default New build 5.3 base or 6.0
ok guys im going to be building a motor so which is the best to start off with. how much can a 6.0 take stock? the plans are HCI and a front mount. more than likely im not gonna use either ones stock intake. so its basically gonna be which has the better heads/block. and where can i find dtroker kits for a 5.3 or 6.0 truck? seems like the only ones i can find are for ls1 cars. are the rotating assemblies the same?
Old Jun 15, 2009 | 10:26 AM
cmiller's Avatar
go with 6.0 block. ls1 rotating are the same for the trucks. sdpc seems to be one of the cheapest to get. just check out the different sponsors.
Old Jun 15, 2009 | 10:30 AM
bk_cauley's Avatar
could you explain why the 6.0 block? not questioning you just curious
Old Jun 15, 2009 | 10:41 AM
00ChevyScott's Avatar
Wearin' da big hat
cause its better. Try searching the forum and you'll see why.
Old Jun 18, 2009 | 07:39 PM
cmiller's Avatar
stronger plus bigger bore for more cubes
but everyone thinks there gold
Old Jun 18, 2009 | 09:19 PM
chevyfan956's Avatar
No replacement for displacement.
Old Jun 23, 2009 | 02:43 PM
wtftalon's Avatar
Talking
except boost
ARC
57
Feb 21, 2022 10:54 AM
USMCvet0311
Aug 14, 2015 10:28 PM
OLD BULL
Aug 1, 2015 05:00 PM
steves86ta
Jul 28, 2015 10:21 AM
justuc
Jul 24, 2015 11:52 PM
