Need some parts on the cheap!!!
Old Nov 3, 2013 | 10:08 AM
Brandon Bogert's Avatar
Talking Need some parts on the cheap!!!
Hey guys, a buddy has been helping me gather parts on the cheap and all i need now is a CAM
I'm looking at
Crane 1449041 210/218 .551/.551 114 (1800 to 6000)
Vinci #043 210/218 .531/.531 114 (1600 to 5800)
There dam near the same but there about $400 new, if anyone can help that would be great.
AND the Corvette YELLOW springs (PAC 1218)
Old Nov 3, 2013 | 10:23 AM
batboy's Avatar
11 Second Club
LS6 yellow springs are not the same as PAC 1218 beehive springs (PAC springs are better). Personally, I would check out the Comp Cams 212/218 "HIGH LIFT" from Texas Speed. They have a good deal on a kit that includes the cam, springs, and pushrods for $610.
Old Nov 3, 2013 | 10:31 AM
I have the pushrods (cromeoly), Whats the difference in the cams i listed and the only you listed, i have a 2002 5.3 4x4 Tahoe, and im looking for more low end TORQUE and a little lope for fun lol, but its still a daily driver for me toting the wife and kid around.
Old Nov 3, 2013 | 10:40 AM
batboy's Avatar
11 Second Club
The Comp Cam I listed is very similar, but has a little more intake duration (see below).
Specifics:
•Basic Operating RPM Range: 1,500-6,800
•Duration at 050 inch Lift: 212 int./218 exh.
•Valve Lift with Factory 1.7:1 Rocker Arm Ratio: 0.558 int./0.563 exh. lift
•Lobe Separation (degrees): 115
•Grind Number: LS1 XR265HR-15
If you want cheap, look at the Trick Flow cam that Summit Racing sells for $288 (216/220 and .560/.560).
Old Nov 3, 2013 | 12:30 PM
gamble686's Avatar
I would get that trick flow 216/220 if I were you. Only $288 shipped brand new. Most cams go for $200-250 used so that is a smoking deal.
Zizzle
Oct 19, 2017 08:44 PM
5.3Caprice
Nov 7, 2015 08:56 PM
axekick
Sep 7, 2015 07:01 PM
Fast86z
Aug 23, 2015 12:35 AM
Sevex
Aug 22, 2015 12:12 AM
