Need some advice with the cam in my LQ4
Old May 2, 2010 | 04:50 PM
mhotrodscooter's Avatar
Default Need some advice with the cam in my LQ4
This is how I ended up with this cam! A friend called a friend & the that friend call someone else & then he calls back with the cam I needed for my LQ4!
So here's the question! What's yalls opinion on this cam? Can I get Alot more power with it?
I've read a lot of forms on cams but haven't found anything r anyone running this type of cam!
Cam spec
intake & exhaust
Lobe seperation=114.1
Valve overlap= -4.2
Intake
Valve open= .5 'btdc
Centerline. 110 'atdc
Duration. 221.4 crank deg
lobe lift. .33311
valve lift. .56629
lobe area = 25.51
exhaust
Valve open = 51.4 'bbdc
Center line. 118 'btdc
Valve close. -4.7
Duration. 226.6
Lobe lift .33087
Valve lift .56247
really would like everybodies opinion don't wanna be pissing in the wind!
lobe area 26.01
Old May 2, 2010 | 05:38 PM
budhayes3's Avatar
PT's Slowest Truck
It sounds like a decent cam, do you know who ground it?
Old May 2, 2010 | 05:59 PM
It's a cam motion grind!
Old May 2, 2010 | 06:01 PM
03sierraslt's Avatar
Is that the same cam as what you have listed in your truck in your sig?
Old May 2, 2010 | 06:02 PM
Atomic's Avatar
I have a gauge for that
221/226 .566/.562 114
sounds decent
Old May 2, 2010 | 06:05 PM
budhayes3's Avatar
PT's Slowest Truck
Now there's a name that I haven't heard in a long time...get us some numbers and let us know how you like it!
Old May 2, 2010 | 06:06 PM
Yes same one
Old May 2, 2010 | 06:09 PM
sounds decent
It does make mad torque! But can I get more with good heads?
Old May 2, 2010 | 06:12 PM
Got some in my sig! Ran 14.15 @ 97mph
Old May 2, 2010 | 10:40 PM
Wheatley's Avatar
Truck Sponsor
I figured it would have atleast been in the mid 13's.HMM
