Need some advice with the cam in my LQ4
This is how I ended up with this cam! A friend called a friend & the that friend call someone else & then he calls back with the cam I needed for my LQ4!
So here's the question! What's yalls opinion on this cam? Can I get Alot more power with it?
I've read a lot of forms on cams but haven't found anything r anyone running this type of cam!
Cam spec
intake & exhaust
Lobe seperation=114.1
Valve overlap= -4.2
Intake
Valve open= .5 'btdc
Centerline. 110 'atdc
Duration. 221.4 crank deg
lobe lift. .33311
valve lift. .56629
lobe area = 25.51
exhaust
Valve open = 51.4 'bbdc
Center line. 118 'btdc
Valve close. -4.7
Duration. 226.6
Lobe lift .33087
Valve lift .56247
really would like everybodies opinion don't wanna be pissing in the wind!
lobe area 26.01
Cam spec
intake & exhaust
Valve overlap= -4.2
Intake
lobe lift. .33311
valve lift. .56629
lobe area = 25.51
exhaust
Valve close. -4.7
Duration. 226.6
Lobe lift .33087
Valve lift .56247
lobe area 26.01
